IPOD help
Old Aug 28, 2007 | 11:06 AM
lil vette's Avatar
lil vette
Default IPOD help
i am having an IPOD installed in my 2002.
I purchased all the cables that are needed from info gathered here.
The shop tried to hook it up last saturday & couldn't get it to work.
I just called & they are in the process to figure out how to install it.
Can someone call 1-800-620-3159 & enlightem them as to how this gets hooked up.
Help
Old Aug 28, 2007 | 11:08 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
More info is needed, like what are you using to interface into the head unit.
Old Aug 28, 2007 | 11:37 AM
lil vette's Avatar
lil vette
Old Aug 28, 2007 | 12:17 PM
rwlc5's Avatar
rwlc5
You unplug the cable from the cd changer in the trunk and plug it in to the appropriate end of the new cable you purchased. Plug the remaining end into the ipod adaptor box. Plug the 12 foot cable into the other side of the ipod adaptor box and the remaining end plugs into your ipod. After you test it out you can run the long cable under the carpet and the console. I cut a hole in the bottom of my cup holder and have the end that plugs into the ipod sticking iut through it. You can then rest the ipod in the cupholder, since it isn't any good for holding cups.
Old Aug 28, 2007 | 12:21 PM
lil vette's Avatar
lil vette
Don't have the cd in trunk option
Old Aug 28, 2007 | 12:27 PM
rwlc5's Avatar
rwlc5
Sorry about that. Check over in the audio section. I know there is something over there. I'm not sure if you can hook into the back of the radio, or if you have to get the cable that would run to the back of the car for use with the cd changer and install it. I believe that cable would install somewhere under the passenger side footwell. The audio section should be able to help you out. Good luck.
Old Aug 28, 2007 | 12:42 PM
PA Z06's Avatar
PA Z06
Its a very straight forward install, I did my install in maybe 25mins, ask them to make sure they have the right switches click, if I remember correct its 3 and 8 need to be swicthed.
Old Aug 28, 2007 | 01:20 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
AND on the front of the instructions there should be a NOTE that says the instructions for Corvettes in the booklet are INCORRECT, and to do xyz!
Old Aug 28, 2007 | 03:24 PM
Humanoid 2.0
I used the PXHGM4 cable with no CD changer.
Old Aug 28, 2007 | 03:25 PM
Humanoid 2.0
Also the unit needs to be unpluged to make and switch changes.
Old Aug 28, 2007 | 03:38 PM
vettelover84's Avatar
vettelover84
Default Missing cable
My 2001 Z doesn't have a rear cd changer either. The cable you listed is only one of the 2 you need to install the interface. I am trying to look it up right now. E-mail the seller and they should be able to tell you the other cable you need.
Old Aug 28, 2007 | 03:43 PM
vettelover84
Here you go this is what I had to get to "make it work"
Item title: Peripheral PXHGM1 iPAC-OEM PXDP PXDX PAC AB-GM9 GM 9pin
Item title: Peripheral GMH20T Vehicle Cable for CHEVROLET Corvette
The two items above are the ables they said I needed to install it correctly. You only have the GMH20T right? you need the AB-GM9 GM 9 pin
hope thats right but i would ask the seller too.
Old Aug 28, 2007 | 03:46 PM
vettelover84
or you can get the PXHGM4.... its the "new" "easier" cable...
To IPOD help
