Matching paint
Old Aug 30, 2007 | 08:36 PM
TraceZ's Avatar
TraceZ
Default Matching paint
What Corvette colors are easiest to match? Hardest?
The color on my Camaro is very hard to match. GM has several different shades of the same color and you have to mess around to see which one matches closest and then tint it to get it perfect.
I want to avoid buying a car that is a color that's hard to color match. I can paint, wetsand and buff, but I am terrible at tinting paint.
Ok, I'll start off the list of colors that are easy to match...
My personal favorite...
Black.
Old Aug 30, 2007 | 08:45 PM
Bob CTS's Avatar
Bob CTS
I have Electron Blue and just had the bumper cover painted and the painter said there were no alternates on Electron Blue. Seems weird but that is what he said.
Old Aug 30, 2007 | 08:46 PM
ValiantSailor's Avatar
ValiantSailor
Millenium Yellow is the hardest on a C5 in MHO.
Black may be easy, but it is also the most dangerous color.
Old Aug 30, 2007 | 08:48 PM
zipity's Avatar
zipity
St. Jude Donor '10
From what I have heard on the C5's stay away from Mil. Yellow and Anniversary Red.
Old Aug 30, 2007 | 08:51 PM
TraceZ's Avatar
TraceZ
It's no problem for me to remove a panel from the car and refinish it if I have to.
Old Aug 30, 2007 | 09:07 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
I have Mag Red and I have heard that is not the easiest to match....
Old Aug 30, 2007 | 09:22 PM
ALVETTE00's Avatar
ALVETTE00
I haven't had luck with GM or DupliColor paint.
There is a place in my area that has a color scanner that they put on the car and can custom make the color to make it match. It'll never be perfect unless you spray with a gun and blend, but it'll be much closer than over the counter stuff.
Good Luck
al
Old Aug 31, 2007 | 01:35 AM
DeeGee's Avatar
DeeGee
Mag Red II is a 3 part color so not the easiest to match
Old Aug 31, 2007 | 03:02 AM
SebringSixSpeed's Avatar
SebringSixSpeed
Color scanner is a must IMHO. I had the targa top painted to match my sebring silver 98. Had the paint supplier do the scanner thing to my roof bow and the match is absolutly perfect.
Old Aug 31, 2007 | 08:42 AM
TraceZ's Avatar
TraceZ
I'm trying to avoid that type of requirement. I'd like to be able to DIY any paint repairs. Good info so far, thanks!
Old Aug 31, 2007 | 12:20 PM
Tom Porter's Avatar
Tom Porter
I have a 97 Sebring Silver. Have you had any body parts touched up. I heard that Sebring Silver is the hardest to match because of the metal flake. I have several areas (stone chips) that I would like fixed but figured I would have to spend the money and paint the whole car.
Old Aug 31, 2007 | 12:44 PM
SebringSixSpeed
For stone chips I use the duplicolor 2n1 for GM 13. works good enough.
Old Aug 31, 2007 | 01:04 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
any metalic in general is tough to match since the "flakes" lay different depending on the gun setup, and distance sprayed, etc.
you will def. want to stay away from both mag. red colors., and also yellow. they have a tinted mid coat.
white is white, red is red, black is black.
the blues are not bad at all.
pewter is hell to match. even under 1 paint code, it has 7 variances of the same color
Old Mar 14, 2024 | 02:30 PM
hyperv6's Avatar
hyperv6
If you use a hood shop matching is no longer a problem. Like stated they scan and mix the paint to match what you have. They can match anything.
if you are doing touch up paint yourself. Red and black are generally easy but even on black all blacks are not the same.
To Matching paint
