C5 Gas Gauge Issues
Old Sep 1, 2007 | 09:09 PM
CCC C5's Avatar
CCC C5
Default C5 Gas Gauge Issues
I know I have seen numerous dicussion concerning aftermarket products that can added to hopefully correct / clean faulty gas gauge sending units in the C5. My 2002, you can rest assured, when the gauge gets to about 3/8 full, the gauge will go to empty and until I fill the tank, it rides on empty.
Please advise what you have used to fix the problem.
Old Sep 1, 2007 | 09:16 PM
Delta3-2's Avatar
Delta3-2
Default Do A Search....
There are tons of comments on this issue. Bottom line....you have to replace the sending units.
DG
Old Sep 1, 2007 | 09:42 PM
env00's Avatar
env00
This works for me...I just pour a bottle of Chevron Techron fuel injector every other fill up. It's about less $10 for a box of 4 at Costco.
Good luck,
- Eric
Old Sep 1, 2007 | 09:44 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Check to see if it is a code being thrown by the computer
Old Sep 1, 2007 | 10:15 PM
Oldvetter's Avatar
Oldvetter
Put in a bottle of Techron. Change your gas to a Top Tier (Shell is one). Use a second bottle on the next tank full if you have to.
Sulphur in fuel does it. Replacing fuel senders just postpones it. Top Tier gas will keep it clean.
Old Sep 1, 2007 | 10:16 PM
R Devil's Avatar
R Devil
Originally Posted by Zilla
Chec k t see if it is a code being thrown bny the computer
I think
Old Sep 1, 2007 | 10:23 PM
Zilla's Avatar
Zilla
Originally Posted by R Devil
I think
My gas gauge drops all the time and it a code relate issue which GM cannot solve. I just reset the code and I am fine.
Old Sep 1, 2007 | 10:54 PM
R Devil's Avatar
R Devil
You have a PM.
Old Sep 1, 2007 | 10:55 PM
rws.1's Avatar
rws.1
#1 cause sulfur build up on the sending unit from using gas with insufficient detergent package....
Use a good fuel system cleaner like Techron fuel system cleaner ( NOT the injector cleaner) , Seafoam.
Berrymans Chemtool B-12, Valvoline Synpower fuel system cleaner for a coule tank fulls and switch to a top tier gasoline www.toptiergas.com
#2. corroded ground for the sending unit
#3. bad sending unit
Old Sep 2, 2007 | 12:00 AM
zTrek's Avatar
zTrek
DG
Nope, not so fast. Had this happen a year ago on my 2002. I put in some Techron and it cleared right up and hasn't happened again.
Bottom line...try Techron first...then if all else fails, look into replacing the sending units...unless your car is nearing the end of a warranty, in which case, you might want to go ahead and replace the sending units just in case they really are defective.
Good luck!
Old Sep 2, 2007 | 01:06 AM
Zilla's Avatar
Zilla
You have a PM.
got it
Old Sep 2, 2007 | 03:01 AM
DeeGee's Avatar
DeeGee
Try the techron fix before you go to the significant expense of dropping the tanks to replace the sensors
Its worked for many of us and it cleans up the sensors/fuel system so its good preventative maintenance.
Old Sep 3, 2007 | 10:23 AM
Harry Bilgewater's Avatar
Harry Bilgewater
Default Which Level Sensor?
It appears there are two float level sensors in the tanks. One in the Left and another in the Right tank.
When I fill my tank I show Full for about 30 miles and then the DIC Red Alerts with the gas guage showing zero fuel left. When the fuel level drops to about 1/3 the DIC Red Alert goes away and the fuel guage will start working again.
I believe it is the right level sensor that is causing the problem as the fuel system empties the right tank first and then uses the contents of the left tank last.
Or I am just going to have to pull both tanks and replace both float level sensors?
Old Sep 3, 2007 | 10:43 AM
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Default STP or Techron works fine
When my gas gage stuck I put in a can of "STP TOTAL FUEL SYSTEM CLEANER" in the tank and filled up. Gas gage works just fine now. I don't know if "TECHRON" is about the same stuff or if it is different. From what I have read on this forum is that either will save you from having to replace a stuck float inside of the fuel tanks.
Ronnie
Old Sep 3, 2007 | 11:01 AM
park83's Avatar
park83
Mine did that last night. I was on a road in the middle of nowhere and suddenly my fuel guage was pegged below "E". I knew I had to have had more gas than that, but figured maybe I was just putting my foot into it more than i thought. Then a warning for "low washer fluid" came on too, even though I hadnt used any of it for a couple days. I finally make it to a gas station and the problem corrects itself, and I have a little over a 1/4 tank left. I was kind of confused. After reading this thread, maybe i'll try some fuel system cleaner.
Old Sep 3, 2007 | 11:40 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Were you anywhere close to Pennsylvania's Roswell? Any bright lights in the sky?
John
Old Sep 3, 2007 | 11:47 AM
11yellowgscpe's Avatar
11yellowgscpe
Chevron gas and Texaco gas have the Techtron in it. If you use that gas you should be alright.
To C5 Gas Gauge Issues
Old Sep 3, 2007 | 11:59 AM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
My fuel gauge is still acting up, despite the last four fill-ups being with Chevron plus a bottle of techron. It seems that when I first start up, the gauge will alternate between "E" and 1/2 full (with a full tank). After driving a bit and sloshing the gas, it will show full OR empty. When it goes to empty, I can jerk the steering wheel to slosh the tanks and the gauge will go back to full. Never stays there though.
Has anybody had their sending units changed? How do you tell if you need to replace one or both?
Old Sep 3, 2007 | 12:00 PM
RSchleder's Avatar
RSchleder
Default Techron
Had the same issue- I filled tank and put in a bottle of techron. Next fill I added a bottle of GM Fuel System PLUS to the tank. Not cheap as it's $25 for the GM PLUS- however, all is well and cheaper than changing sensors, etc, out of tank. Good luck, Ron
Old Sep 3, 2007 | 12:24 PM
park83's Avatar
park83
John
haha
I was actually driving from Pittsburgh...so who knows.
