Right now I have the stock 18/17 rims on my 03 Z. I run Nitto road race tires in 305/35/18 and 275/40/17. The front in 275/40 (Nitto desnt make a 265/40 which would be great) is too tall a sidewall compared to the rears and with really hard cornering it is not good and I can feel it, plus visually the front tire looks much larger.
Im deciding on maybe going with a same size 18" rim on the front as the rears and using a 285/35 sized tire (which has a lower profile sidewall than the 275/40) to make it the same sidewall profile as rear with 35 measurement for better handling.
Any idea if this will throw off the computer, ABS, AH and such? There is still a small diameter difference between the front and rear tire size but dont wanna upset the car any.
I've been running 18x9.5f and 18x11r for almost 4 years.... no issues. On track I run 17x11 w/ 315's all around. However, I run w/ AH/TC all off. Sometimes on my warmup session I have comp mode on an AH still functions fine.
