Air conditioning
Old Sep 11, 2007 | 05:51 PM
vetterlatethannever's Avatar
vetterlatethannever
Does that work? May have to check it out next time, hopefully it will be a while.
Old Sep 11, 2007 | 05:59 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by zbeastls1
i had the same problem dealer change the compressor
Unfortunately you got bent over, big time. Did the dealer at least kiss you when they were through with you?
Old Sep 11, 2007 | 10:34 PM
jazzmk1's Avatar
jazzmk1
Default Ac
I had this happen on my 2000 vert once. I just played with the controls and soon both sides were back to ice cold. There were no codes listed on the DIC.. just my 2Cents worth.. mark
Old Sep 14, 2007 | 06:34 PM
greatguy42's Avatar
greatguy42
Default it could be
mine did the same thing
one of the blend doors was stuck
easy to fix but the bad part is the whole dash has to come out
Old Sep 14, 2007 | 06:42 PM
TEXHAWK0's Avatar
TEXHAWK0
We discussed this topic just last week at one of our Corvette club gatherings. I was also thinking that if one side cooled and the other did not, then it was actuator doors. Two members of the club said that adding just a little freon fixed their problem.
Old Sep 16, 2007 | 08:14 PM
Melodie's Avatar
Melodie
I'm gonna pray for a freon fix I think we all know why.
Old Sep 17, 2007 | 09:44 AM
egypt123's Avatar
egypt123
Any good reads or how-to's out there on servicing the A/C system (i.e.; adding freon, correct pressures, correct way to check the system, etc.)?
EDIT: Never mind... The search tool is a wonderful thing.
http://forums.corvetteforum.com/show...t=adding+freon
Old Sep 17, 2007 | 10:32 AM
egypt123's Avatar
egypt123
Sorry to hijack this thread, but I figured since it pertained to A/C issues, it may be helpful so I put here. Question:
I recently put leak dye into my A/C system to see if there was a leak. Upon black light inspection, I could not find any leaks. However, after running the car for awhile, I've noticed green dye on the ground under the car. Could this be coming out with normal A/C condensation or is it a true indication there's a leak somewhere?
Old Sep 17, 2007 | 02:42 PM
Melodie's Avatar
Melodie
I would like that info as well.
Old Sep 17, 2007 | 03:45 PM
Robls6's Avatar
Robls6
If you have a leak in the evaporator, the dye might be mixing with the condensation coming off the evaporator coil when it gets cold. It could be mixing with the condensation and then running on the ground.
Old Sep 18, 2007 | 05:06 PM
LoneStarFRC
And in that case you would have zero cooling as well as all the freon would have come out as well.
Old Sep 19, 2007 | 08:45 PM
Melodie's Avatar
Melodie
additional info: don't drive the car much-just noticed that the air is just a little cold on the drivers side while freezing on passenger side? What does this mean?
Old Sep 20, 2007 | 04:22 PM
  #33
SebringSixSpeed's Avatar
SebringSixSpeed
Same prob, cool on pass side only. Clearing the 0441 code which automatically recalibrated the actuator solved the problem. Cold all around now! Thanks Corvette Forum!!!
Old Sep 20, 2007 | 04:42 PM
  #34
Junkman2008's Avatar
Junkman2008
Originally Posted by tonio76
My 99 Vert was blowing cold out of the passenger vents and warm out of the drivers. I had the system purged and refilled and now its ice cold all vents.
When mine did that, I had to reset a fuse and the problem went away. I read it somewhere on some forum and then saw a service bullitin on it too. The stealer filled my freon and that did no good, but my problem was intermittent, not constant. I had to tell them how to fix it.
Worthless butt suckers.
Old Sep 20, 2007 | 05:54 PM
  #35
Melodie's Avatar
Melodie
ok, thanks!
Old Sep 20, 2007 | 05:58 PM
  #36
Ralphyboy's Avatar
Ralphyboy
Originally Posted by Tact
If you mean that the air blows hotter on the driver's side it could possibly be the A/C actuators need to be calibrated. Pull up your DIC and see if you have a history/current code B0361.
Check for codes. If you get the codes for a left side actuator not functioning, there is a post about recalibrating it. I did it in my car, and it was very difficult to get at the part. The process eliminated the code, but not the real issue.However, when I went to the dealer (the real problem with my vette was a leak near the compressor) they told me that there was a way to recalibrate the actuator WITHOUT removing it. I didn't ask since I already removed it and reset it, but you might inquire about this. Good luck.
Old Sep 21, 2007 | 12:15 AM
  #37
Melodie's Avatar
Melodie
thanks
To Air conditioning
Old Sep 21, 2007 | 09:08 AM
  #38
egypt123's Avatar
egypt123
Does the "recalibration of the actuator" only apply if you have the dual-zone adjustments on the climate control unit? Mine (a manual/analog, single-zone climate control unit) was doing this and adding a splash of freon fixed the problem. Just curious...
Old Sep 25, 2007 | 12:44 PM
  #39
Quarklt1's Avatar
Quarklt1
Cruising
Default Quarklt1
Just had the same problem on a 1999 dual zone system added some freon problem fixed
Old Sep 25, 2007 | 05:26 PM
  #40
Melodie's Avatar
Melodie
Thanks!
