Air conditioning
Old Sep 4, 2007 | 09:12 PM
Melodie's Avatar
Melodie
Default Air conditioning
anyone had their air on one side go out? It's working fine on the passenger side.
Old Sep 4, 2007 | 09:48 PM
zbeastls1's Avatar
zbeastls1
5th Gear
Default aircondition
i had the same problem dealer change the compressor
Old Sep 5, 2007 | 01:16 AM
Melodie's Avatar
Melodie
ok, I'll check out both issues. Thanks!
Old Sep 5, 2007 | 09:18 AM
jrose7004's Avatar
jrose7004
My 98 used to do that when it needed freon.
Old Sep 5, 2007 | 09:44 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
If you mean that the air blows hotter on the driver's side it could possibly be the A/C actuators need to be calibrated. Pull up your DIC and see if you have a history/current code B0361.
Old Sep 5, 2007 | 11:27 AM
Melodie's Avatar
Melodie
Thanks! I'll check this all out. I'm hoping it is freon since I just spent $700.00 having leaks under my 82 fixed for Rte 66.
Old Sep 5, 2007 | 12:03 PM
tonio76's Avatar
tonio76
My 99 Vert was blowing cold out of the passenger vents and warm out of the drivers. I had the system purged and refilled and now its ice cold all vents.
Old Sep 5, 2007 | 12:55 PM
JR_VET's Avatar
JR_VET
A/C actuators
Old Sep 5, 2007 | 02:10 PM
Melodie's Avatar
Melodie
"purged and refilled." Meaning freon?
Old Sep 6, 2007 | 03:52 PM
DJKP's Avatar
DJKP
3rd Gear
Default Air Conditioning
I had the same problem as well. I was told thaat it needed to be recalibrated. However at the same time I was having a problem with the positive post on the battery staying tight. Found out that thecomputer system was setting and re-setting itself as the post was hot then not. Once I got the post fixed the system has worked fine every since.
Old Sep 6, 2007 | 04:11 PM
Melodie's Avatar
Melodie
that sounds like a tough one!
Old Sep 6, 2007 | 04:16 PM
T VETTE's Avatar
T VETTE
I think this same question comes up every week. Must be a weak link in the system.
Old Sep 6, 2007 | 05:02 PM
Melodie's Avatar
Melodie
for me-I'm gonna go with the freon first. The car is a 98 and living in LV, it sounds like it could be very likely.
Old Sep 11, 2007 | 10:57 AM
bighank's Avatar
bighank
Default Don't Overfill With Freon
The total charge in the C5 is just a hair under 2 cans of freon. If you OVERCHARGE it will not cool properly. I just replaced the expansion orfice tube (about $2.50) in the high pressure side line, evacuated and recharged with 2 cans and it still wasn't cooling. Found that the vacuum check valve had a crack in it and my inside actuators weren't working. $3.44 at Advance in the help section to replace the valve.
My plastic vacuum lines had rotted out like MOST C5s with the Delco batteries and I replaced them about 2 years ago. Now on my 3rd check valve but it cools fine NOW. Goodluck BIGHANK
Old Sep 11, 2007 | 11:20 AM
Melodie's Avatar
Melodie
Wow! Thanks!
I was thinking this may be something i could handle myself-maybe not!
Old Sep 11, 2007 | 12:32 PM
peebee_c5's Avatar
peebee_c5
These suggestions to change the compressor or recharge the freon make no sense to me at all. Not saying you're wrong, or that these solutions didn't work, just that I don't understand how either of those could possibly fix the problem.
How would a bad compressor or low freon lead to cold air out of one duct and warm air out the other?!?
Old Sep 11, 2007 | 12:44 PM
vetterlatethannever's Avatar
vetterlatethannever
Low freon fixed mine.
Apparently since some C5 have the dual climate control the sides are separated, when low the drivers side is the one that fails to cool first.
To Air conditioning
Old Sep 11, 2007 | 01:18 PM
peebee_c5's Avatar
peebee_c5
Ahhh... maybe they have two evaporators, one for each side of the car....
Thanks.
Old Sep 11, 2007 | 03:22 PM
tonio76's Avatar
tonio76
These suggestions
Low freon fixed mine too
Old Sep 11, 2007 | 04:44 PM
bighank's Avatar
bighank
Default put the controls on recirc and 60 degrees
If you have dual controls like on my 98 set the temp to 60 degrees and air on top vents and recirc. It should blow COLD air out of both sides since the pasanger control is inoperative at either min (60 degrees) or max (90 degrees). If the temps are different when you do this maybe an actuator is stuck. Make sure you have vacuum to the purple hose which feeds the vacuum actuator switch. If NOT then search on vacuum leaks and leaky battery and fix that first. BIGHANK
