Active handling warming up?
Old Sep 5, 2007 | 08:27 AM
Tombone's Avatar
Tombone
Default Active handling warming up?
I have had my car for 6 years and this year this prompt comes up periodically. Does this happen to you, and is this a sign of my car aging?
Old Sep 5, 2007 | 08:31 AM
Phanni's Avatar
Phanni
You might want to check your battery. I had a marginal battery and different codes would show when I hadn't driven the car for a week or two. My battery had one weak cell, when I replaced the battery, the interrmitent problem was gone.
BTW, I love the grill work.
Old Sep 5, 2007 | 09:01 AM
rws.1's Avatar
rws.1
No,
On start up the car goes thru a self test cycle.
During that time if you drive other than in a straight line and the sensors detect some slippage in one of the wheels you get the message while it is trying to complete its iniitation. Once it has concluded that the signal it sensed is not a sensor fault it then gives a warm-up complete message.
Old Sep 5, 2007 | 09:02 AM
MisterC's Avatar
MisterC
I don't drive my car daily so on the mornings that I do drive it, I get the message. I think it's purely informational and gives no cause for worry.
Old Sep 5, 2007 | 10:47 AM
02MillenniumVette's Avatar
02MillenniumVette
Originally Posted by rws.1
No,
Old Sep 5, 2007 | 11:05 AM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
Believe it or not...I was also told once that you could sometimes get this code if you have been parked on an incline for an extended period.
I can't swear if it's true.
Old Sep 5, 2007 | 12:21 PM
Nothing to worry about. Here's what my owner's manual says about that message:
When you first start your vehicle (especially during cold winter weather), and begin to drive away (up to 6 mph), the message ACT HNDLG - WARMING UP may be displayed in the DIC, the instrument panel cluster light will be on, and a chime will sound. This is normal. You can acknowledge this message by pressing the RESET button. The Active Handling System performance is affected until the next message WARM UP COMPLETE is displayed in the DIC.
Under cold weather conditions, this message may continue up to 12 mph for 30 seconds. The Active Handling system is off until the WARM UP COMPLETE message is displayed.
While it specifically mentions cold weather as a time when this message can appear, it can also appear in warm weather. My '99 had active handling on it and the message popped up on it a number of times.
Old Sep 5, 2007 | 01:41 PM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
No,
I'll vouch for that! Every day I pull out of my driveway taking a right 90 degree turn and I get the AH "warming up" chime every time, even if it's 90 degrees out. I have an '04 and a new battery to boot!
John
Old Sep 5, 2007 | 05:46 PM
Tombone's Avatar
Tombone
Thanks for this detailed answer...........you guys are GREAT!
Thanks again, Tom.
Old Sep 5, 2007 | 05:53 PM
robertlthomson's Avatar
robertlthomson
Nice to know and a great "heads up". Since cold weather is on it's way I will be ready. This forum is incredible!
Old Sep 5, 2007 | 06:02 PM
flyin c5's Avatar
flyin c5
Mine came on once,When I was leaving Blomington gold after I was park at the golf course on A hill. 04
To Active handling warming up?
