dried seals
Furthermore, todays seals are made with a high silicone content lessening the chance for "dry out". Over a very long period of time seals will get brittle and can leak. This is due mostly from ozone & atmospheric conditions....again, it takes a looong time.
The reason you dont hear much on this as far as a C5 goes is because its not very prevalent. On the other hand, if you have a car that has had many heat cycles & alot of miles, I would fear leaks being more of a problem.
A garage queen has set inside a garage with very few miles on it, which means no extreme temperatures, in most cases. Combine that with todays modern materials seals are made with & I think theres a slim chance for trouble.
I bought my Black '99 Coupe last year with only 1658 miles on it and have not had one single issue with the car. It was however properly maintained and stored in a heated and airconditioned room along with many other Corvettes, collectible cars and motorcycles.
