check engine light
Old Sep 8, 2007 | 05:43 PM
C5Wolfe's Avatar
C5Wolfe
Default check engine light
Its a fairly cool evening so I take the Vette out for a short run. I do a burnout and make a short pass. Then the stupid check engine light comes on! Its running fine but the light came on. Any clue on why its on and how do I turn the damn thing off? Its done this before for no reason and usually goes out after a few days! Any ideas out there?
Thanks,
Dave
Old Sep 8, 2007 | 05:51 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Pull your codes...write them down for future reference and then reset your d.i.c.
This will clear your codes and engine light will go out.
Have this problem looked at!
Old Sep 8, 2007 | 05:53 PM
PugLover's Avatar
PugLover
My check engine light would come on every couple of days so I changed the bank 2 number 2 oxygen sensor. Hope this helps.
Mark
Old Sep 8, 2007 | 06:01 PM
C5Wolfe's Avatar
C5Wolfe
How do you pull the codes? and how do you reset the dic?
Old Sep 8, 2007 | 06:53 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
1. Press "Options" until you reach the blank space (right after "Languages)
2. Keep it pressed while you press "Fuel" 4 times...
It will go into Diagnostics and automatcially start scrolling thru the codes for each computer (PCM, BCM, etc)...
When you see a code with a C after it, this indicates current code...H indicates History code.
Press E/M to exit.
Dave
Old Sep 8, 2007 | 07:22 PM
WWK888's Avatar
WWK888
Mark
Without pulling codes, he would have no idea what is causing the light to come on.
To check engine light
