Biggest cam for daily driving? MS3/4 too much?
Old 09-08-2007, 08:31 PM
PolishDude
PolishDude's Avatar
Default Biggest cam for daily driving? MS3/4 too much?
Okay I dont care if the car has a choppy idle or shakes a bit when at a light but i do need it to be driveable and want to not change the valvetrain every 10k miles. I want it to be fine when cruising at 1500-2000 rpms in 6th. I have stock gears in the rear end and the stock z06 tranny and plan on keeping that way. I have port and polished heads, is an ms3 or ms4 a good choice or should i go with something less agressive for daily driving? RevX will check if my heads have been milled (done by previous owner) because i obviously dont want any valve clearance issues. Im looking for hp in the 440rwhp-450rwhp range if possible. I doubt i can expect more without a fast mani...
I have:
Full Exhaust
Underdrive pulley
z06 intake mani (obviously)
apparently a good set of ported/polished heads
vararam
I want/need to decide by tuesday morning
Old 09-08-2007, 09:06 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I would go with a 224/228 cam w/580+ lift on a 114 lobe center for an A4 plus you can keep it legal
Could go alittle higher with a MN6 tranny 228/228 or 228/230 with 580 + lift!
This has a mild chop and awesome performance!
Just my .02 cents!
Thanks,Matt
Old 09-08-2007, 09:10 PM
chris308
chris308's Avatar
have you thought about one of EG's signature cams? Those things are wicked sounding!!
Old 09-08-2007, 09:11 PM
WKMCD
WKMCD's Avatar
I ran a 230-236 112 cam in my 346. I had a 90/90 setup and made 460 with an SD tune. I drove it in DC rush hour without problems. I really don't know that I'd want to go any bigger than that. Remember, it's all in the tune.
Old 09-08-2007, 10:57 PM
PolishDude
PolishDude's Avatar
def want something in the 230s at least. I have a z06 so its a 6 speed for me. The shop is going to have a cam ground for me through comp cams so no go on the eg cams.
Old 09-08-2007, 11:09 PM
chris308
chris308's Avatar
I believe Comp grinds EG's cams, i'm sure i seen it here...
Old 09-08-2007, 11:11 PM
PolishDude
PolishDude's Avatar
yeah but i think revx wants to be the one to get it from comp so they make some $$ on it
Old 09-08-2007, 11:12 PM
chris308
chris308's Avatar
ah, gotcha!
Old 09-08-2007, 11:14 PM
BADMFR
BADMFR's Avatar
St. Jude Donor '08
definitely don't be shy on your cam selection. I was a wuss and stuck with the ole 224/228 114lsa. While not "unhappy" with it, I wish I would have gone bigger. mid/high 230's if not low 240's Mine is extremely reliable, with awesome DD manners, but will be swapping soon.
Old 09-08-2007, 11:35 PM
PolishDude
PolishDude's Avatar
yeah i currently have a 222/222 .566/.566 112 lsa so i need something bigger then high 220s
Old 09-08-2007, 11:47 PM
BADMFR
BADMFR's Avatar
St. Jude Donor '08
you just having your shortblock rebuilt or what? if not I might be interested in selling you my longblock making 435/400 and talk to revx about something new and exciting for me
Old 09-08-2007, 11:48 PM
vetterlatethannever
vetterlatethannever's Avatar
Go big!! Like WKMCD said, driveablility is mostly in the tune.
Old 09-08-2007, 11:57 PM
BADMFR
BADMFR's Avatar
St. Jude Donor '08
Originally Posted by vetterlatethannever
Go big!!
If you're gonna be a bear, be a F'n GRIZZLY BEAR!
Old 09-09-2007, 12:24 AM
PolishDude
PolishDude's Avatar
they are going to rebuild my block, nothing exciting though, just a bigger cam
Old 09-09-2007, 12:30 AM
_Will_
_Will_'s Avatar
Location: Somewhere between mild insanity and complete psychosis
Something similar to a g5x-3 would be good. MS3 and MS4 are a bit much for the street. They're more track cams (or dyno queen). g5x-3 is just about right for a z06.
Old 09-09-2007, 12:37 AM
PolishDude
PolishDude's Avatar
any idea what the specs are on those? mid 230s?
Old 09-09-2007, 06:08 PM
PolishDude
PolishDude's Avatar
ttt
To Biggest cam for daily driving? MS3/4 too much?
Old 09-09-2007, 09:42 PM
jacks996
Jacks996
jacks996's Avatar
Cruise-In VIII Veteran
I have all his parts on my car now and have no problems driving at all
Old 09-09-2007, 09:58 PM
0euro@EFIAlchemy.com
Former Vendor
euro@EFIAlchemy.com's Avatar
seriously beg to differ, the MS3 is just fine for the street if tuned right and is far from a "dyno queen" cam
Old 09-09-2007, 10:09 PM
Rob'sC5
Rob'sC5's Avatar
Cruise-In V Veteran
St. Jude's Donor '05
238/244 596/612 114+2. I've have had this cam in for 3 years with no issues. I've got 4.10 gears and just made a trip to Hot Springs and got 29 mpg, average around 75-80mph.
Quick Reply: Biggest cam for daily driving? MS3/4 too much?
