Magnaflow Installed
Old Sep 10, 2007 | 10:36 PM
PewtVette's Avatar
PewtVette
Default Magnaflow Installed
I Just finished installing a Magnaflow cat-back & X pipe this weekend. I was extremely impressed by the quality of this system. Fit & finish was excellent and the install was very easy. As for the sound- in the lower RPMs, quiet but basey. In the upper RPMs, louder of course, but not too loud. I'm trying to refrain from using terms like 'really awesome' so I'll just say, 'really freakin nice'. I assume the X-pipe had a least something to do with the sound. BTW, the Magnaflow (cat-back & X) came in 10lbs heavier than the very crappy sounding stock system.
Old Sep 10, 2007 | 10:40 PM
jon c's Avatar
jon c
I have had my magnaflow xpipe and catback system for a couple years and still love it, it is quality stuff.........you have a very nice car
Old Sep 10, 2007 | 10:42 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Very nice looking system and a clean install
Old Sep 10, 2007 | 10:44 PM
Wake Champ's Avatar
Wake Champ
Where's the sound clip?
Old Sep 10, 2007 | 10:49 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
NIce...any drone issues? your car...6 spd or auto?
Old Sep 10, 2007 | 10:50 PM
PewtVette's Avatar
PewtVette
Thanks all, I've only had the car for just over a month.
BTW, I didn't mean to say that all stock exhaust systems sound bad. Mine rattled and spitted. Mostly rattled.
Hmm, I need to work on that- I promise.
Old Sep 10, 2007 | 10:53 PM
PewtVette's Avatar
PewtVette
Haven't had a chance to run it on the HWY. Based on my research, I suspect no drone (or minimal). It's a m6.
Old Sep 10, 2007 | 10:56 PM
jon c's Avatar
jon c
on my set I have the x-pipe and catbacks and I have NO drone at all, I have an A4 and I really like the system, would buy the same setup again
Old Sep 10, 2007 | 11:02 PM
PewtVette's Avatar
PewtVette
well since you brought it up, here's a couple of front views:
Old Sep 10, 2007 | 11:06 PM
PewtVette's Avatar
PewtVette
... I have an A4 and I really like the system, would buy the same setup again
Agreed. I'm kinda surprised more folks aren't running this system.
Old Sep 10, 2007 | 11:35 PM
IIXLR8's Avatar
IIXLR8
MN6's are less proned to drone with magnaflow.........than 2.73 a4 cars.
The drone with magnaflow rears its ugly head at the 1700 - 1800 rpm range which in a 2.73 geared car, IS HIGHWAY SPEED.
The lower the rpms running at highway speeds the worse the drone becomes.
To magnaflows credit, their drone is not nearly as bad as some of the others out there...........it's basically tolerable, but note, there is drone, albeit slight.
The look, sound, fit , finish and build quality, more than make up for this slight nusance.
3.42 gearing in an a4 tame the drone considerably and it's far less noticable than a 2.73 geared car, but still exists.
At wide open throttle Magnaflows system is not as loud as say, corsa, or borlas stingers, but somehow manage to sounds classier than both its competitors with its deep throaty rumble that screams " power."
As looks go, its large tips and polished finish are very hard to beat, giving some added demension to the rear of a C5 that the others don't.
Tip alignment is made simple and perfect courtesy of Magnaflow, thanks to their exhaust plate which is included in the package.
The plate , in and of itself is extremely nice and fits directly between the pipe tips perfectly, and is not some stick on piece that adheres with double sided tape to some platic component underneath the Corvette. It is a TRUE exhaust plate, Billet Aluminum, which in itself also gives the rear of the c5 a look that the others do not.
Perhaps the premier cat back system for the C5 Corvette and probably the system that the car should have come with.
The system is slightly heavier than stock, perhaps , roughly 10 lbs which is a non issue if the driver simply loses 15 pounds, equating to 5 less pounds.
Fitment is a breeze of perfection.............
Pictures do not do it justice.
Old Sep 10, 2007 | 11:41 PM
PewtVette's Avatar
PewtVette
Yeah, I was going to say all that but I decided to go ahead and let you handle it.
Nicely written.
-Jay
Old Sep 10, 2007 | 11:42 PM
IIXLR8's Avatar
IIXLR8
lol
Yeah, I was reading your mind.
it's all true.
congrats on the new system..............you're going to get lots of looks.
I think you'll be happy with it
Old Sep 11, 2007 | 12:06 AM
RxConsult's Avatar
RxConsult
I've had the Magnaflow x-pipes and exhaust for 4 years. My vette is an every day driver, so having too loud an exhaust wasn't for me. The Magnaflow gives a nice low growl at idle, and at WOT it's good but I'd probably like a little more roar. (I have a MN6)
As for drone, it's minimal. There's just a bit at about 1600 to 1800 RPM in 6th gear. So if you're cruising at 70 mph in 6th, there's just a bit of drone especially if you accelerate a bit without down shifting as it creeps from 1600 through 1800 RPM.
Old Sep 11, 2007 | 01:13 PM
robertlthomson's Avatar
robertlthomson
Love my system too. For just a bit more "throat-e-ness" I also went with Bassanni High Flow Cats. No change in drone.
Old Sep 11, 2007 | 03:02 PM
Max Grip's Avatar
Max Grip
Congrats on the install, I'm glad you like it. Your car looks great, is it stock, other than the exhaust?
I'd love to hear your car, I'm pretty close to you. Mine's pewter as well!
Old Sep 12, 2007 | 05:16 PM
Flipside's Avatar
Flipside
After much deliberation I have decided to put the magnaflow 15660 on my 50th AR coupe. But I am concerned about the bracket that connects the two sides. It looks like the bracket will cover the 50th anniversary plate that came with the car.
What does one do about that? Can I move the 50th anniversary plate and put it on top of the magnaflow bracket? Will it fit there?
Based on what I have read, heard and the great price I can get for the installed 15660 system, I am sold on it. I'd just like to know what to do about the plate.
Kirk
To Magnaflow Installed
Old Sep 12, 2007 | 05:21 PM
vetterlatethannever's Avatar
vetterlatethannever
Looks like a very clean system!
Old Sep 12, 2007 | 07:42 PM
PewtVette's Avatar
PewtVette
Originally Posted by Flipside
...Can I move the 50th anniversary plate and put it on top of the magnaflow bracket? Will it fit there?...Kirk
You would probably have to cut that plate down to make it fit but you could definitely mount it on top of the Magnaflow plate:
Check this out:
http://forums.corvetteforum.com/show...agnaflow+plate
Old Sep 12, 2007 | 07:52 PM
PewtVette's Avatar
PewtVette
Stock for now. I have a '02 Z28 that I bought new and I had heads, cam, and exhaust on it by 15k miles.
I will be doing a mild cam on the C5 and possibly heads (some day).
I saw a pewter C5 on 66 on Sunday. I was going to catch up to it but an unmarked state trooper pulled up next to me so I got off at (Vienna/Fairfax).
I'll look for you.
