Nitrogen
Old Sep 11, 2007 | 10:01 PM
Dark-Knight's Avatar
Dark-Knight
Default Nitrogen
Will replacing the air in my runflats with nitrogen in anyway damage the tires or sensors?
Thanks for your reply!
Old Sep 11, 2007 | 10:09 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
It wont harm your sensors.
A lot of people have different opinions on this subject.
Mine is;
Nitrogen is a waste on a car if you dont race it. The purpose of nitrogen is to replace the oxygen. Oxygen holds water molecules and reacts to temperature changes in an undesireable way - therefore nitrogen would be better. However, IMHO the typical driver will never notice the difference.
Old Sep 11, 2007 | 10:24 PM
Dark-Knight
I want to replace the air as nitrogen molecules are larger, causing less loss of pressure, resulting in less irritation with low tire pressure notices on cold mornings.
Nitrogen on costs $5 a tire, NBD.
Old Sep 11, 2007 | 11:07 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
You have 78 percent nitrogen already, so it won't damage anything but your wallet. If you can get it for free get it. This subject has been beaten to death, best to do a search.
Old Sep 11, 2007 | 11:18 PM
vetterlatethannever's Avatar
vetterlatethannever
Old Sep 11, 2007 | 11:34 PM
rws.1's Avatar
rws.1
Nitronize your tires... you will get higher gas mileage and your tires will last up to 30% longer....
Old Sep 11, 2007 | 11:37 PM
thisMSGgood4me's Avatar
thisMSGgood4me
And it will keep your hair from falling out as you get older too.
Old Sep 12, 2007 | 12:09 AM
utryd2's Avatar
utryd2
You will also lose 1/10th of a second for each tire you have done in the 1/4 mile, and hook better
Old Sep 12, 2007 | 12:11 AM
vetterlatethannever
Can you say snake oil????
Old Sep 12, 2007 | 12:12 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Nitrogen
You will also get 21.5% more horsepower.......Remember, if you should have an erection that last longer than four hours.......call all of your best friends or Doctor.....I can never remember which.....
Old Sep 12, 2007 | 12:14 AM
jrose7004's Avatar
jrose7004
He's right you know!
Old Sep 12, 2007 | 12:18 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
No it wont hurt them ! !
Old Sep 12, 2007 | 12:24 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
woops...see next post...
Old Sep 12, 2007 | 12:25 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Heres my experience with the nitrogen in the tires theory>>>
3 weeks ago I got new tires (Michelins)on one of my vehicles at Costco. Costco now uses nitrogen exclusively in tires. I was told that I could keep 30 psi and even after driving on the highway in the summer that it would not expand...I have tested the tire psi for the last 3 weeks many times and cold it reads 30...then I go driving for an hour or so in 85-95 degree temp on the highway and city driving mixed and then take the reading and everytime I have tested it this way the hot reading shows 34.5 psi...I tested it with 3 different good guages...same reading.
So in conclusion after "scientifically" testing cold then hot Costcos information that the nitrogen in the tires does not expand is pure BULLCHITT
As far as I can tell it is a gimmic to sell more tires.....but this is just a semi-educated guess on my part
NOTE:...Buyer of the "Nitrogen being way better than regular air "theory beware
P.S.>>>the Michelins ride Great!
Old Sep 12, 2007 | 01:13 AM
MrLeadFoot's Avatar
MrLeadFoot
You must be me! I just put new tires on at Costco 3 weeks ago, with nitrogen, too!
Although I had them set at 33 psi cold, I've noticed they hit 36 psi when hot. Before you go thinking that they hit that high because I started with a higher pressure than 30 cold, it's been 3 weeks and my pressures have dropped to 28 and 29 psi in the mornings, and it's 80 degrees in the mornings here, right now, and they STILL ramp up to 36.
Bottom line is that I'm seeing MUCH higher swings now than I did before with regular air!
Old Sep 12, 2007 | 01:37 AM
DeeGee's Avatar
DeeGee
I also had N2 when I got the tires fitted at Costco
Not a jot of a difference between N2 and O2
Save the $$$$
Old Sep 12, 2007 | 06:41 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
To answer your question it won't hurt your tire pressure sensors. The only real advantage to nitrogen fill is if you are planning long term storage of the car. The rest is simply a way to separate you from your money.
To Nitrogen
Old Sep 12, 2007 | 09:28 AM
R Devil's Avatar
R Devil
QFT
Old Sep 12, 2007 | 09:56 AM
ROADAPPLE's Avatar
ROADAPPLE
Joseph ("Paper Collar Joe") Bessimer said it best when he said,"There's a sucker born every minute...and two to take 'em."
Old Sep 12, 2007 | 02:30 PM
Red89gt's Avatar
Red89gt
Used to fill the tires on the aircraft when I serviced them in the military with nitrogen. Doesn't fluctuate like regular air would at different altitude and temperature extremes or there would be no tires to land on.
