invisicord help
Old Sep 14, 2007 | 02:04 AM
RedRckC5's Avatar
RedRckC5
Default invisicord help
does anyone have a detail step by step on using the invisicord to power an escort 8500 to the passenger ffootweel? I am using the mirror to power my xm radio.
Old Sep 14, 2007 | 03:16 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Owners Manual
The Owners Manual tells you where and which color the wires to use under the footwell. I wired my Valentine One that way and I pulled the "A" pillar trim off of the passenger side windshield to route the wiring and dropped it down through the side well area and right behind the glove box and down into the passenger foot well area. Now it is a very clean install. Hope this helps....'ya
utryd2's Avatar
utryd2
The way I did mine was did it with a new longer power cord down the back side of the dash to the fuse panel on the pass side footboard......The cord they give it is not long enough to have it on the center of the car......It is a bit of a paiin.......I also got the cord to where it has the remote mute button and mounted that next to my leg in next to the shifter.....
Old Sep 14, 2007 | 09:55 AM
Ryan's Daddy Dan-Na
Default Location of wires
BTW, the wires are kind of in the mid to upper left hand part of the footwell cubby hole. you can find them just read the owners manual for the description of the wires. There is one that is hot with the key and one hot all the time like the battery. For my Valentine One I used the one that is hot with the key. If ya need pictures I can provide you some this evening when I move mine to wash her.
Old Sep 14, 2007 | 10:28 PM
RedRckC5's Avatar
RedRckC5
should i reinstall my xm to the passenger footwell and hook the radar to the mirror? Also, how many inches of cords do i need to reach the footwell?
Old Sep 14, 2007 | 10:31 PM
RedRckC5's Avatar
RedRckC5
use to hang out at Hollywood Casino! Sure miss cruising up and down Fox river. Thanks for the info!
To invisicord help
