If this is true?
Old Sep 14, 2007 | 02:55 PM
buckdog06's Avatar
buckdog06
Default If this is true?
From what is below- I have a '01 vert. Do I have a LS6? I thought I had a LS1. It says "All Corvettes now have the LS6 intake manifold and block"
2001
* Return to 28# injectors for all models.
* Second Generation Active Handling
* Nassau Blue discontinued
* Alternator 'clutch' pulley added on A4 cars
* New soundproofing + foam in all cars
* Smaller key fob
* Electro chromic dimming rearview and driver's mirrors
* Lighter AGM battery
* Thickness + Material in Convertible change
* Chrome exhaust tips for coupe + Convertible
* 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
* LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
* All Corvettes now have the LS6 intake manifold
* All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
* LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
* Hardtop/FRC discontinued
* Stronger synchros in all transmissions
* Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
* Metal valve stem caps (late year)
* Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm.
* Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
* Introduction of the Z06, which has as differences:
* Hardtop body style
* Rear brake ducting
* Screened inlets on front fascia, without fog lights
* F1 Super car tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
* New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
* M12 transmission with shorter gearing (1-2-3 analogous to MN6 with 3.90 rear diff
* Titanium exhaust system
* Lightweight windshield
* New, stronger clutch with redesigned master + slave cylinder
* Stronger rear differential (shotpeened ring gear)
* Red brake calipers (otherwise identical)
* Transmission overtemp warning light on DIC
* 6500 redline gauges with special checkering + Z06 font
* Redesigned PCV system to help combat oil burning
* Red LS6 Fuel Rail Covers (FRC's)
* FE4 Z06 suspension - up rated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
Old Sep 14, 2007 | 03:23 PM
SilvaDragon's Avatar
SilvaDragon
Starting in 2001 all Corvette motors shared a common block and
intake manifold, in both cases the better units designed for the
LS6. But only the Z06 came with a full LS6 motor, all other cars
came with the LS1.
Old Sep 14, 2007 | 03:29 PM
utryd2's Avatar
utryd2
came with the LS1.
Old Sep 14, 2007 | 04:05 PM
DefenderC5's Avatar
DefenderC5
You have a LS1
Old Sep 14, 2007 | 04:39 PM
C5XTASY's Avatar
C5XTASY
Starting in 2001 all Corvette motors shared a common block and intake manifold
and injectors. You do indeed have an LS1, however.
Ed
Old Sep 14, 2007 | 04:45 PM
91LSMAN's Avatar
91LSMAN
To the best of my knowledge the heads and cam are what really make the LS6 different from the LS1. While the intake manifold and block are different, the difference in minimal, from what I understand.
Old Sep 14, 2007 | 04:46 PM
R Devil's Avatar
R Devil
I can see how you were confused after reading that.
Old Sep 14, 2007 | 05:35 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Reads (to me at least) that they are discussing differences about the 2000 to the 2001 and introducing the new ZO6 information all in the same write up.
I really didn't read that this is strictly a VERT they were discussing.
BTW, your VERT has the LS1 with an LS6 intake manifold on it.
Micah
To If this is true?
