Climate control..why does it do this?
When i turn the fan on and turn up the heat to a temperature above the exterior temp., the A/C light goes on and when i press it to turn it off it blinks a few times and stays on..i can't get the A/C light to turn off?
"The air conditioning does not operate
at temperatures below approximately 35F to 40F
(2 deg C to 4 degC). The light on the A/C button will flash if
pressed when air conditioning is not available. The air
conditioning cools and dehumidifies the air coming into
the vehicle. The air conditioning cannot be turned off in
defrost and defog, as it helps to remove moisture from
the vehicle. It also helps to keep the windows clear."
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
The ac has a dehumidifier mode and cant be turned off when defrost or defog is selected. maybe you turned it off in one of those modes? From the book:
and right from the owners manual
You need to change the mode.......
