[Z06] Tune w/ basic mods?
Old Sep 15, 2007 | 03:41 AM
EFNFAST's Avatar
EFNFAST
Default Tune w/ basic mods?
Is there any point in getting a tune with just basic mods (b&b bullets and blackwing for performance) - if so, any ideas how much I could expect to pick up? Thanks.
Old Sep 15, 2007 | 07:07 AM
Joy of 6's Avatar
Joy of 6
Probably no more than 15 to 20 HP, but the tuner can disable the skip shift (and other non essentials) and tune the fuel delivery mapping so that the car runs at the most efficient level. that's ther real advantage without some serious mods.. Your gas mileage might go up a few MPG also.
Old Sep 15, 2007 | 08:46 AM
u4ick's Avatar
u4ick
When I did a tune only I gained about 35rwhp, at $450 that's pretty cheap HP per dollar.
Plus as stated above your car will run alot better.
Old Sep 15, 2007 | 02:43 PM
vms4evr's Avatar
vms4evr
With nothing more than an after market filter on my 02 Z06 I got a dyno tune. 28hp/12tq to the wheels simply by adjusting the A/F ratios to clean them up. The stock tune works good but a dyno tune works better. I spent $300 for the tune.
Then add setting the cooling fan on/off temps to something better, removing skip shift, torque mgmt, rev limiter, etc... Not to mention the tune is set for a car that is used on track. Nothing drastic or on the edge. Just a cleaner curve. I didn't get better gas mileage but it isn't worse. You can feel 28hp at 4Krpms.
Try and get that kind of performance improvement for $300 with bolt ons...
Old Sep 15, 2007 | 03:48 PM
mtm87tx's Avatar
mtm87tx
what are your plans down the road? and ask your shop how much re-tunes are
Old Sep 15, 2007 | 06:37 PM
utryd2's Avatar
utryd2
If I was you I would do it....the first dyno charge is the bggest....can always go in and re-tune it for otehr parts added on for hourly rates most the time
To Tune w/ basic mods?
