brake noise
Old Sep 17, 2007 | 06:14 PM
EPMM 03 C5's Avatar
EPMM 03 C5
Default brake noise
ok..i hear all the time that all vette brakes make noise!! why? and is there something you can do about it??
opinons?
eric
Old Sep 17, 2007 | 06:17 PM
sailohio's Avatar
sailohio
My brakes don't make noise. What is your noise like?
Old Sep 17, 2007 | 06:25 PM
EPMM 03 C5's Avatar
EPMM 03 C5
i can't really explain it..there just noisy all the time..is it the pads or the rotors?
eric
Old Sep 18, 2007 | 01:29 PM
sailohio's Avatar
sailohio
I have ceramic pads. I put them on to reduce brake dust all over the side of my car. I like them. When I brake I hear the slight scraping sound of the pads on the rotor but it isn't very loud. I won't hear it if the windows are up. So if you are getting more sound than that you have an issue. If it is a higher pitched sound it may be the wear sensor is too close to the rotor. If it grinds all the time it could be the pads are worn out and you have the metal backing scaring up your rotors. A constant grinding sound may mean you have a wheel bearing going out. You should have a brake shop look it over, if you can trust them.
Old Sep 18, 2007 | 01:35 PM
T VETTE's Avatar
T VETTE
How many miles on veh? May be time for some Quiet Stop low dust Reybestos Ceramic pads !
Old Sep 18, 2007 | 03:18 PM
rws.1's Avatar
rws.1
The harder the pads, the greater the noise...
GO ceramic..... low noise and low dust...
To brake noise
