Automatic Headlights
Sep 18, 2007 | 08:07 AM
Does anyone know of a way to turn off the automatic headlight feature on the c5? The lights pop up even after I get gas in the middle of the day because I am sitting in the shade, and it is really annoying. Thanks
Sep 18, 2007 | 08:09 AM
Using the DIC ( options, configure) turn off twilight sentinel... when twilight sentinel is on the DIC hit reset...
Sep 18, 2007 | 08:31 AM
Sep 18, 2007 | 09:34 AM
Quote:
Originally Posted by
rws.1
Turn it off, it's a pain.
Sep 19, 2007 | 09:06 AM
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
rws.1
I did this turned them off after two years of having the lights pop up everytime i started the car in the garage.
Sep 19, 2007 | 10:25 AM
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If you have a Canadian model then you can not shut it off.
May 23, 2015 | 05:29 PM
screw991le
If you have the Canadian model (which does not have a defeat feature for the auto headlights), try
corvettegadgetman.com
$20, takes a few minutes to install, comes with good instructions, and is about as easy as it gets.
May 23, 2015 | 09:41 PM
Another benefit of turning the twilight sentinel off is it will save wear and tear on the headlight motors.
May 24, 2015 | 02:04 AM
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
When all else fail, read the manual. Same answer today as eight years ago.
