EGR block off plates
Old Sep 19, 2007 | 04:11 PM
Specter's Avatar
Specter
Default EGR block off plates
Would they do anything good? How bad could they be aside from codes?
I just want to know if they are worth the time, or are worthless.
Old Sep 20, 2007 | 12:29 PM
Specter's Avatar
Specter
No one knows?
Old Sep 20, 2007 | 12:46 PM
gpracer1's Avatar
gpracer1
I wasnt aware the C5 had an EGR.
Old Sep 20, 2007 | 12:59 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Are you talking about AIR Tubes
Are you talking about the AIR tubes? All they do is inject fresh air into the exhaust manifold. The pump is not driven off the engine. If you remove them they can be edited out.
Bob K.
Old Sep 30, 2007 | 05:27 PM
Specter's Avatar
Specter
I was looking at all the parts they sell on sites that sell mods for late modle GM cars etc and saw EGR blockoff plates, I've never looked to see if the c5 has them, but I thought at least all OBDII+ cars had them for some reason, could easily be wrong though as it was a hearsay kinda thing.
Old Sep 30, 2007 | 07:22 PM
Patches's Avatar
Patches
No EGR on the C5. There is on the f-body LS1 though. Check out the f-body intake manifold right behind the TB.
Old Oct 1, 2007 | 06:14 PM
Specter's Avatar
Specter
Its a pretty small area where it could connect lol, after the TB and before heads. I should have checked but I assumed based on one aftermarket site.
Old Oct 1, 2007 | 06:49 PM
Patches's Avatar
Patches
You can see the EGR hose in the top pic and the entry point with the hose removed in the right side of the bottom pic. The light grey one next to it is the aftermarket FAST LSx replacement manifold. Notice the EGR is blocked of on that one.
Old Oct 1, 2007 | 08:04 PM
LoneStarFRC's Avatar
LoneStarFRC
True story!
Old Oct 1, 2007 | 11:52 PM
snailrail's Avatar
snailrail
If you decide to remove the air tubes, there is a bolt holding the rear tube to the back of the driver side head. It is hell to get to. You can not see it, so you must loosen it by feel only. The good news is you only have to loosen it, not remove it, but I hope you have small hands. Removing the system, the pump is under the left headlight, won't gain you any power, but it would shave a couple of pounds. As was said above, you will have to have the error codes programmed out.
To EGR block off plates
