Tire Size Question?
Old Sep 19, 2007 | 06:00 PM
premier333's Avatar
premier333
Default Tire Size Question?
Can someone tell me what is the biggest size tire I can put on stock 2002 C5 wheels without any problems? I want to go wider....
Old Sep 19, 2007 | 06:35 PM
premier333's Avatar
premier333
anyone know?
Old Sep 19, 2007 | 07:43 PM
Bill Vett's Avatar
Bill Vett
Old Sep 19, 2007 | 08:27 PM
premier333's Avatar
premier333
Originally Posted by Bill Vett
255/285
35, 40 or 45?
Old Sep 19, 2007 | 09:03 PM
PaulWall's Avatar
PaulWall
tire height doesnt matter for the rim it matters whether it will rub against the car tho. Id personally do 255/40/17 and 285/35/18 but thats me
Old Sep 19, 2007 | 09:49 PM
edensknight's Avatar
edensknight
Go To The Head of The Class! The specific tire sizes recommended above are what would be termed a correct "Plus 0" tire size upgrade upon the same sized Corvette C5 original equipment wheels. The o.e. Corvette C5 wheel sizes are 17X8.5 Fronts which are coupled with 18X9.5 Rears from the GM Corvette Factory. FYI: The 8.5 inch wide wheel is an ideal wheel width for an 255mm tire, and, a 285mm tire is also recommended upon a 9.5 inch wide wheel. This is a great option-alternative for Corvette C5 owners who do not wish to purchase a costly larger and wider custom wheel and tire package for their C5, when you can simply upgrade the tire sizes upon the o.e. Corvette C5 wheels with this Plus 0 tire size upgrade. Falken, Goodyear, Pirelli, Yokohama, and, Michelins, etc. are just some of the many tire brand options available to you in this specific Plus 0 sizing with the Falken tire (FK-451, and, FK-452) being the best low cost value.
Old Sep 20, 2007 | 07:41 AM
premier333's Avatar
premier333
So the 255/40/17 and 285/35/18 would be the best fit and wouldn't rub. My next question is would it make the car sit any lower?
Old Sep 20, 2007 | 12:21 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Use this calculator to get your answer. You can try any combination, but PaulWall has the right answer
The 285/35/18 is 25.85" Diameter vs 275/40/40 at 26.66" Diameter
http://pw1.netcom.com/~sgalaba/tiresize.htm#TireSize
Dave
Old Sep 20, 2007 | 04:57 PM
edensknight
Hello, Chuck! You have an informative and helpful PM. Best wishes!
Old Sep 20, 2007 | 08:09 PM
HarleynVettes's Avatar
HarleynVettes
Old Sep 12, 2008 | 07:13 PM
slvrC5vert's Avatar
slvrC5vert
can i fit a 315 on a 17x9.5 rim on my 2000 convertable? its stock hieght...
To Tire Size Question?
