Wheel size?
Old Sep 21, 2007 | 11:19 AM
pk1's Avatar
pk1
Default Wheel size?
Will a 19 x 11 wheel with a 57mm offset be ok or will it stick out too far?
Old Sep 21, 2007 | 11:23 AM
jdmvette's Avatar
jdmvette
Night Owl for life
should sit about flush, but the tire might bulge past the fender a lil.
i had 19x11 @ +63mm w/305/30/19 and those tucked in awesome, so the extra 6mm shouldnt be too bad.
Old Sep 27, 2007 | 06:10 PM
pk1's Avatar
pk1
There on the car and they do stick out but not bad.
Old Sep 27, 2007 | 06:54 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
My CCW's are 19x11" with 56mm offset. They are close to being flush... sidewall is out about 7/16" but tread is inder fender.
Also, camber is nearly -0.4 so if you add a bit of negative camber, they will lean inward a bit more.
To Wheel size?
