a question about run flats
Extended Mobility Tires (EMT)
Every Corvette is equipped with "Run-Flat" Goodyear Extended Mobility Tires (EMT) that help eliminate the need for a spare. The tire design helps enable safe function during and after loss of pressure for up to 100 miles of continuous driving at 55 mph. Keep in mind that the shorter the distance you drive with the loss of pressure, the better the chance that the tire can be repaired.
Rick
Plus I carried a small air compressor and plug kit in the back and had emergency road service on my insurance along with a cell phone.
"If a tire goes flat, you won’t need to stop on the side of the road to change the tire. You can just keep on driving. The shorter the distance you drive and the slower the speed, the greater the chance that the tire will not have to be replaced. If you drive on a deflated EMT for 50 miles (80 km) or less and at speeds of 55 mph (90 km/h) or less, there is a good chance that the tire can be repaired. The tire can operate effectively with no air pressure for up to 200 miles (320 km) at speeds up to 55 mph (90 km/h), but the tire would then have to be replaced."
Unless you are drag racing your Vette, there is nothing wrong with the OEM tires. If you don't like the OEMs, its your car, feel free to change them.
IMHO, I like the safety margin of the GY Eagle F-1 GS EMTs. I have not found them to be rough riding, noisy, or bad handling. The Michelins are OK, but IMHO they don't look like they belong on a Vette (I had them on my old Vette so I am speaking from personal experience).
I think you are asking for trouble by running non-run flats on a car with no spare and no room to store one. You may be lucky and never need a spare, but on flip side, you might catch one at the wrong time and in the wrong place. ALL C6 Vettes (Z06 included) come with run flat tires (hmmmm).
Just remember that run flat technology, in fact a lot of innovative car technology, started out as standard equipment on Corvettes. The tires are but one example. Everyone wants to equate what is best for the Track with what is best for the street. This forum is not indicative of what most Corvette owners do to their cars. Most don't try to turn the car into something that it is not.
The car is not Caddy, so you will have road noise, engine noise, tire noise, etc. (I LOVE the noise personally). It is also not a race car or a dragster, unless you spend and inordinate amount of money to turn it into one which most people who go this route don't do the right way because they are not willing to spend the cash to do it and/or take short cuts.
Bottom line: do what you want to your car, your way
Good Luck.
