a question about run flats
Old Sep 23, 2007 | 02:43 PM
bm bradley's Avatar
bm bradley
Default a question about run flats
what are you guys doing about flats that are running the 'regular' tires? I've had blow outs going about 100 mph before. no problem with the run flats. the dash lit up and told me to slow down to below 55.. didn't really even have any handling issues. I've gotten about 7 flats with my vette since I've had it. almost always 'drywall screws' from all the construction in the area I live in. how do you handle blow outs and flats with no run flats? sure would like to have a quieter set of tires on the car -bmb
Old Sep 23, 2007 | 02:49 PM
maxvalley's Avatar
maxvalley
Run flats and vert, don't think I would switch out the michelins are not that loud.
Old Sep 23, 2007 | 03:02 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Default Blow outs
I replaced my old runflats with new runflats due to the blow out and no spare possibility. I don't autocross so the Goodyear runflats handle just fine for me and I like the security just in case....... To each their own.
Old Sep 23, 2007 | 03:07 PM
DeeGee's Avatar
DeeGee
Like you I've had my fair share of nails so I went with new runflats for that reason. I've already been glad I made that decision when I broke a tire valve and the tire deflated. I'd have been stranded otherwise.
I fitted Michelin AS ZPs. Much quieter but still give the peace of mind of a runflat.
Old Sep 23, 2007 | 03:12 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
If it helps you any I have a full set avg. 5/32" Also have a pair of 9/32 fronts . A single 10/32 rear and a single 9/32 front. Pair of 9/32 rears.
All Goodyear F1's runflat.
Old Sep 23, 2007 | 04:11 PM
RREDTOY's Avatar
RREDTOY
Default Run flats
I just purchased a set of Michelin AS ZP's. I had a puncture with my Goodyears that had 25k miles on them. I was originally thinking about getting non-run flats until the puncture. When they switched out my tires, I had a screw in the other rear tire.
The Michelin's are night and day difference fom the old Goodyears
Old Sep 23, 2007 | 04:22 PM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
Same here. Got my new GY run flats this spring.
Old Sep 23, 2007 | 04:31 PM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
"The Michelin's are night and day difference fom the old Goodyears."
My sentiments exactly!
Old Sep 23, 2007 | 04:36 PM
02MillenniumVette's Avatar
02MillenniumVette
I hope I dont get a nail in my tire. Havent had a flat yet with my non runcraps on. Ive gotten a few nails in my tires before but it only caused a very slow leak so I could get it repaired before it went flat. So far Ive never had a blow out.
Old Sep 23, 2007 | 05:29 PM
bm bradley's Avatar
bm bradley
guess I'm gonna look into these for next time. thanks guys. bmb
Old Sep 23, 2007 | 05:32 PM
moserbe's Avatar
moserbe
Michelin runflats are what I will replace my GY with when it's time.
Old Sep 23, 2007 | 06:18 PM
jmrc5's Avatar
jmrc5
How far can you drive with zero pressure on the Michelins?
Oh well, it probably doesn't matter since no one seems to want to repair a runflat. I will definitely stick with runflats, but will probably give the Michelins a try.
Old Sep 23, 2007 | 06:27 PM
bm bradley's Avatar
bm bradley
100 miles on the GY
Old Sep 23, 2007 | 07:58 PM
jrprich's Avatar
jrprich
I have had Michelin ZPs repaired........was no problem at Discount Tire
Old Sep 23, 2007 | 09:35 PM
SPIVET's Avatar
SPIVET
Originally Posted by bm bradley
100 miles on the GY
I'm pretty sure it's 200 miles @ 55MPH for the GY (it's in the owner's manual). I think Michelin and others are only 50 miles (not sure if its at highway speeds though?).
Old Sep 23, 2007 | 09:39 PM
bm bradley's Avatar
bm bradley
the dealer said 50, the corvette website says 100 if I remember correctly. check this out:
http://www.runflatinternational.com/...FQgZhgodaTgh7w
Old Sep 23, 2007 | 09:43 PM
Tom73's Avatar
Tom73
GY is 50 miles and still be repairable or up to 200 miles if needed but will need to replace the tire. For most of the others you will have to replace the tire if driven more than just a few miles and the max miles is 50.
One thing I have never understood. So may people complain about the tire/road noise with runflats. The Vette is a SPORTS CAR not a Caddy or Lincoln. Why even put a radio in them? The car makes more then enough beautiful music for me.
tom...
To a question about run flats
Old Sep 23, 2007 | 09:46 PM
bm bradley's Avatar
bm bradley
goodyear says 50-55 miles
http://www.goodyear.ca/tires/technology/runflat.html
Old Sep 23, 2007 | 09:47 PM
bm bradley's Avatar
bm bradley
tom...
I had to go 200 with a flat and I chose to get a 'tow' if the tire went might have ripped body panels off and ruined a wheel. that was a $900 flat.
Old Sep 23, 2007 | 09:49 PM
bm bradley's Avatar
bm bradley
from the corvette website:
Extended Mobility Tires (EMT)
Every Corvette is equipped with "Run-Flat" Goodyear Extended Mobility Tires (EMT) that help eliminate the need for a spare. The tire design helps enable safe function during and after loss of pressure for up to 100 miles of continuous driving at 55 mph. Keep in mind that the shorter the distance you drive with the loss of pressure, the better the chance that the tire can be repaired.
