Wheels that will not Ballance
Old Sep 25, 2007 | 04:47 PM
mooneym20s01's Avatar
mooneym20s01
Default Wheels that will not Ballance
I just bought wheels off tire rakck becuase the current wheels i had would not ballance..bought them off ebay which was the wrong thing to do. Just got the new wheels on and they are bouncing just like the others did. It is not a constant vibration it just bounces every 2 to 3 seconds and is driving me CRAZY!!!! It has stick on weights on it should i have the clip on ones on it or should i take it somewhere else to get it ballanced.
Thanks Jeremy
Old Sep 25, 2007 | 04:52 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
3 words >> Hunter Roadforce Balance
If you'd fill in your profile someone may have a local suggestion for you.
Old Sep 25, 2007 | 05:14 PM
Bob CTS's Avatar
Bob CTS
Old Sep 25, 2007 | 06:38 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
have it balanced with a hunter road force balance machine. If you have cheap aftermarket wheels they arent made as well and the balance is off. I have 2 z06 repro wheels that won't balance
Old Sep 25, 2007 | 06:49 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
I have an older car with a set of true spoke wheels on them. I could never get them to ballance till someone told me to have the tire shop first static balance then without removing any weights from the static balance to spin balance. Surprising enough this process worked I no longer have any wheel vibration at any speed
Old Sep 25, 2007 | 06:54 PM
mooneym20s01
where can i find a hunter road force balance machine
Old Sep 25, 2007 | 07:30 PM
R Devil's Avatar
R Devil
How can someone answer that if you don't fill out your profile or at least tell us where your located?
Old Sep 25, 2007 | 07:31 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Fill out your profile
Jeremy, if you fill out your profile and show at least what state or city you reside in, then you can bounce your way to a smoooooth ride once again, into the sunset of which ever state you live?
Old Sep 25, 2007 | 08:00 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Somewhere in the USA (if that is where you live)
The question is almost impossible to answer until you tell us where you live
Old Sep 25, 2007 | 11:20 PM
mooneym20s01
ok sorry i updated my profile now where can i find one of them there balancing machines
Old Sep 26, 2007 | 01:56 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
Check with a Discount tire shop if you have one. Otherwise might try the yellow pages, add might indicate the force balancing. If that doesn't work you might check your shocks if the car has a few miles on it. That can also cause some tire vibration.
Old Sep 26, 2007 | 07:05 AM
Bugaboo's Avatar
Bugaboo
do a search for Hunter Road Force.........their site will have info by state and locality..........
Old Sep 26, 2007 | 07:38 AM
rws.1's Avatar
rws.1
follow this link and enter the requested data to find a hunter roadforce balancer near you...
http://www.gsp9700.com/pub/search/FindGSP9700.cfm
Old Sep 26, 2007 | 07:48 AM
napoleonvette's Avatar
napoleonvette
Default tire balance
Try Grant Tire in Kingsport they have a road force balancer and do a good job. They are very carefull with Corvettes
Old Sep 26, 2007 | 08:03 AM
Buckskinner's Avatar
Buckskinner
Default kudos
ain't it wunderful, no matter whur yew is if'n ye needs hep, thar's always sumwun here thets glad ta offer info, an do whut ever they can ta hep yew.
Old Sep 26, 2007 | 09:45 AM
Are you positive that it is the wheels that are the problem? What about the tires? Find a place with the Hunter Road Force machine and see what they can find. Good luck.
To Wheels that will not Ballance
