Door Lock Problem Help!!
Old Sep 25, 2007 | 07:53 PM
Ta-taaa's Avatar
Ta-taaa
Default Door Lock Problem Help!!
I have a strange problem with my drivers door lock.
It will not "Lock" with the remote. I have to lock the door manually. The passanger door works fine.
Both doors will Unlock with the remote with no problems.
Any ideas??
Thanks!
Old Sep 25, 2007 | 07:57 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If you attempt to lock the door from the inside of the car with the driver's control, does it lock?
Old Sep 25, 2007 | 08:03 PM
Ta-taaa's Avatar
Ta-taaa
No.. the passanger door locks but not the drivers. I thought it might be the linkage, but counting that out, because it locks.
Old Sep 25, 2007 | 09:18 PM
RedSoxFan's Avatar
RedSoxFan
I have the same issue, I plan on replacing the relay in the control module. I've got the new relay and a solder sucker, I just haven't gotten around to attempting the surgery yet.
Old Sep 25, 2007 | 09:45 PM
Ta-taaa's Avatar
Ta-taaa
Hey let me know if that works.. !
Old Sep 25, 2007 | 09:49 PM
dgrant3830's Avatar
dgrant3830
It does sound like the door control module is the cause. The relays can be replaced as RedSoxFan said.
Old Sep 26, 2007 | 12:17 AM
rws.1's Avatar
rws.1
check out this link.... you want the Door Control module subsection
http://www.ronjpics.com/Corvettestuff.htm
Old Sep 26, 2007 | 01:29 AM
mark man's Avatar
mark man
I had the same problem i also thought control module lots of $, but not so all i did was take door panel off and lubed linkage ( WD-40 ) works with the remote every time. Can't hurt to try worked for me.
Old Sep 26, 2007 | 01:31 AM
DeeGee's Avatar
DeeGee
Those are exactly the symptoms I had and the dealer replaced the door module under warranty
This is the definitive thread on the forum covering the fix. You can either replace the module or theres a relay fix here as well.
http://forums.corvetteforum.com/show...ht=door+module
Old Sep 26, 2007 | 05:47 AM
Ta-taaa's Avatar
Ta-taaa
Thanks guys!! Now I know what I am doing this weekend!..
To Door Lock Problem Help!!
