Battery/Electrical Question
Old Sep 27, 2007 | 10:20 AM
Barneyfife911's Avatar
Barneyfife911
Default Battery/Electrical Question
I just had to replace a NAPA 75 month battery (their best) after less than a year. It was completely dead - would not charge or even jump start. My question is this. Is there a way I can find out if my 2001 vert is somehow discharging the battery or if I just had a bad battery? I have added LED license and exhaust plate lights from Richard as well as fuel pressure/boost gauges for the supercharger and Raptor shift light, but don't see how any of that could drain the battery when car is in garage. I do have one of those 1.5 amp trickle chargers. Should I just keep that attached when stored, or would that be bad for a new battery? Any thoughts? Thanks for any input or ideas.
Old Sep 27, 2007 | 11:26 AM
rpm462's Avatar
rpm462
Do a search using Bill Curlee's name under C5 Tech...lot of threads on how to troubleshoot this with a multimeter. Went through this a while back and he was a big help.
Old Sep 27, 2007 | 11:31 AM
bighank's Avatar
bighank
Default Got 9 months from a Sams battery
Probably just a bad battery. You should get a new one at no charge if it is that new. I did. Remember NEW does NOT EQUAL GOOD
New means new only. BIGHANK
Old Sep 27, 2007 | 11:35 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Hopefully your added lights and guages are powered via switched sources. The LED's wont draw hardly anything, but the other lights and guages will.
To Battery/Electrical Question
