Fog Lights
Old Sep 28, 2007 | 03:50 PM
Munky's Avatar
Munky
Default Fog Lights
I have an FRC with out fog lights, and am interested in installing a set. Does anyone have suggestions, or experience with OEM vs Aftermarket?
I am looking to find out what brands will work, or do I need to go with OEM.
Any information is appreciated.
Thanks.
Old Sep 28, 2007 | 04:22 PM
Bill Vett's Avatar
Bill Vett
www.mvpautoparts.com
He has everything you'll need. I have the PIAA's and love them. Bill
Old Sep 28, 2007 | 04:36 PM
Munky's Avatar
Munky
Which pia's did you get?
Old Sep 28, 2007 | 05:24 PM
Bill Vett's Avatar
Bill Vett
1100's Taun has the brackets, wiring comes with the lights.
Old Sep 29, 2007 | 09:56 PM
HollywoodFRC's Avatar
HollywoodFRC
Default I put them in a '99 FRC
Got a used set from Gene at Karshop with a switch, bought the crush nuts from the dealer that the lights mount to. I didn't get a used wiring harness so I bought the pig tails for the lights from Gene Culley at GM parts direct. Bought the Black (Ground) and Purple (power) wire from NAPA. After I spent all of that it cost more than PIAAS which have better performance. But I like the stock fisheye look and use of stock components. Good luck. Do a search on 'Fog Lights' and someone posted a schematic for the circuit. Even though the wiring IS NOT in the FRC, the relay is in the fuse box in the battery compartment. Good luck.
Old Sep 29, 2007 | 11:44 PM
The PIAAs would be a very good choice.
Old Sep 29, 2007 | 11:52 PM
Sportsdude's Avatar
Sportsdude
Old Sep 30, 2007 | 08:46 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Easy install with Tuan's Brackets.
https://www.corvetteforum.com/techti...=130&TopicID=1
Old Sep 30, 2007 | 08:50 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'd look here in the For Sale section for a set of used ones from a Vette being parted out - At least you'll be able to keep someones Vette alive by using their lights!
I would assume that the wireing is there!
Thanks,Matt
Old Sep 30, 2007 | 12:19 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I wish I had of done this years ago !
Here is the write up I did on installing C5 Fog lights in my Z06. I then installed HID bulbs in my fogs, and low beams. Its not difficult, just a little elbow grease and common sence.
You will not believe how cool the HID fogs and low beams look !
Nothing else even comes close.....
http://forums.corvetteforum.com/show...p?p=1562048743
Toque
Old Sep 30, 2007 | 04:34 PM
jdmvette's Avatar
jdmvette
Night Owl for life
To Fog Lights
