Check Engine
Old Sep 30, 2007 | 10:12 AM
triple black c4's Avatar
triple black c4
Default Check Engine
About a week ago I stopped and filled with gas and when I started the car the check engine light came on. I read the owners manual and it said that this could happen after filling the tank and that after a few trips that the light would go out. I have taken the car out about 4 times since this happened and it has not went away. Does anyone know how many trips it takes or should I be getting it checked? Any coments appreciated. Thanks
Old Sep 30, 2007 | 10:18 AM
rws.1's Avatar
rws.1
IF the CEL is on, the DIC will display codes.
Run the codes and post them here...
Don't know how to get the codes?
DO a search on C5 codes.
Old Sep 30, 2007 | 10:20 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
First - folloow these steps:
http://forums.corvetteforum.com/show....php?t=1625418
Then, copy codes found and review them against this:
http://www.gearchatter.com/index10.p...e0914816539da2
Then post the code for us - then we can assist
Old Sep 30, 2007 | 10:59 AM
triple black c4
Now I know why I love this forum so much, when you ask for help you get it. Thanks guys I printed the information out and now out to the garage to see what I can figure out. I will keep you posted on what I found out. Again Thank You for your help. Ron
Old Sep 30, 2007 | 11:03 AM
DBL001's Avatar
DBL001
1 quick check is to make sure the gas cap is on tight, if it wasn't tightened past the first click....u can get a check eng. light
Old Sep 30, 2007 | 11:57 AM
triple black c4
Thanks everyone, I pulled the codes and the code that shows H & C is code P0 0803 under the 10 PCM that says 1-4 Upshift solenoid control circut (MT). I do have a skip shift eleminator installed could that have anything to do with it? Thanks
Old Sep 30, 2007 | 01:03 PM
GOZ2FST's Avatar
GOZ2FST
When mine came on I just cleared several months of codes - all temporary - and the light went out.
Old Sep 30, 2007 | 01:08 PM
oaks99's Avatar
oaks99
oak
To Check Engine
