[Z06] C5 shock PNs question
Old Sep 30, 2007 | 11:32 AM
zulatr's Avatar
zulatr
Default C5 shock PNs question
I pulled the shocks, which I thought were original, from my 03 Z and replaced them with Bilstein sports.
The front shock PN is 10419093, which according to other posts is correct for the car.
The rear shock is 10314571, which doesn't show up in any posts about shock PNs.
Any idea what the rear shocks are?
thanks,
mk
Old Oct 1, 2007 | 12:36 PM
zulatr's Avatar
zulatr
ttt
Old Oct 1, 2007 | 01:28 PM
BlackZ06's Avatar
BlackZ06
Default Hope this helps ....
A quick web search turned up this .....
http://www.fatherlarryscorvetteshop....php/t-465.html
You might try Gene at
http://www.gmpartshouse.com
and see if he can help. My 2001 Z06 had the following factory installed shocks on it:
10419096 - rear
10419093 - front
I installed the 2004 Z06 shocks which showed part numbers:
10339945 - rear
10339944 - front
Old Oct 1, 2007 | 04:48 PM
zulatr's Avatar
zulatr
10419096 - rear
10419093 - front
10339945 - rear
10339944 - front
with the link you sent to fatherlarry, I see I'm at least reading the PN right on the rear shock.
So, it looks like front shocks were the same from 01 - 03, and the rear shock changed somewhere between 01 and 03, and none are the same as the 04 Z shocks.
I always thought the 01 front and rear were different, the 02 -03 were the same, and the 04 had a new set of PNs.
I'll try Gene and see what he thinks....
To C5 shock PNs question
