oil filter question
Old Sep 30, 2007 | 08:03 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Default oil filter question
I feel like such an idiot having to post about this but here it goes.
I did the first oil change on my C5. I used the parts look up catalog and picked up a 3506 (pretty sure but regardless of the number, it was the filter that was for the C5). when I took the old filter off, it is a PF 46. I was a little worried but the only difference I can see is the 46 is a bit longer. the 3506 fits fine and there is no oil leaking under my car so I guess that is a good sign.
please help me out because I feel pretty dumb :o
any insight?
BTW...I did do a search
Old Sep 30, 2007 | 08:37 PM
ALVETTE00's Avatar
ALVETTE00
Should be fine(that is the right Fram), but how much longer is it? Being a bottom-mounted filter and the C5 being a ground-hugger, you know!
Old Sep 30, 2007 | 08:41 PM
Cjunkie's Avatar
Cjunkie
Fram filters have NEVER had a good reputation and your saying this one is shorter which tell me it is going to filter LESS (smaller filter area)....why wouldnt you spend the extra dollar and get the right AC-Delco???
Old Sep 30, 2007 | 08:42 PM
moserbe's Avatar
moserbe
I believe that you can use two different AC Delco filters on the C5 also, PF44 or PF46. I believe that the only difference is the length.
Old Sep 30, 2007 | 08:46 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
first off, thanks for the replies. The fram is shorter so I am not concerned about the clearnce but I appreciate the warning
next...I know I know I know I should have bought the delco but I have a legitamate excuse. I had to get the oil changed and no delaerships are open here on a Sunday. I did buy the top of the line fram-it cost me about $12 (Canadian) so I hope it is a little better than the regular one. When I need a change next year I promise I will get (at least) the delco!
thanks for the help...and the
Old Sep 30, 2007 | 11:20 PM
Cajun99's Avatar
Cajun99
Nope...your excuse is lame
The PF46 can be bought at nearly any auto parts store. The one place I've found that does not carry them is Wally World.
Old Sep 30, 2007 | 11:23 PM
rws.1's Avatar
rws.1
next time go with NAPA Gold, Wix, Purolator, K&N, Mobil 1,
Old Sep 30, 2007 | 11:25 PM
scottydog's Avatar
scottydog
Fram filters are the absolute bottom of the barrel!
Wix/NAPA, Mobil1 are better choices.
Old Sep 30, 2007 | 11:26 PM
jon c's Avatar
jon c
Now we have him confused
Old Sep 30, 2007 | 11:28 PM
WetteVette's Avatar
WetteVette
Anything is better than a Fram!
Personally, I like the Wix. And remember to be absolutely sure to get the right size (height). A little too long and that puppy will be snapped right off!
Old Sep 30, 2007 | 11:37 PM
TNX ZORA's Avatar
TNX ZORA
At one time I thought that Fram probably made a good filter. That was back in '73. Just as I was about to install one on the 454 in our new 4 spd. coupe, I looked down inside it and saw metal shavings. Never touched another Fram, likely never will.
You'll probably be OK this one time with a Fram but I wouldn't keep trusting my luck if I was you.
Old Sep 30, 2007 | 11:43 PM
b98's Avatar
b98
K&N
Old Oct 1, 2007 | 12:13 AM
2 GRUMPY's Avatar
2 GRUMPY
Mobil 1
Old Oct 1, 2007 | 12:52 AM
DeeGee's Avatar
DeeGee
any insight?
Not sure you got an answer to your question
Looks like its the correct filter and if its not leaking I'd say you're good to go. When all said and done the filters there to take out the large particles. Were talking fine details here so theres no panic to change it straight awy.
You'll always get opinions around here on which are the best oil, tires, filters etc but quite often the opinions are not supported by facts. FRAM make a lot of filters so I'd say you'll be fine under the circumstances. Granted they're maybe not the best but it depends how long you keep the oil in the car. If you normally run 100% on the DIC and you're still worried, you might want to condsider an early change to get the correct filter back on.
JMHO
Old Oct 1, 2007 | 08:51 AM
steve8's Avatar
steve8
I think the 46 has replaced the 44.
Old Oct 1, 2007 | 12:59 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Thanks for all of the advice guys...invaluable as usual!
Wally didn't even have a filter to fit so I had to go to canadian tire. they had regular fram, 'synthetic' fram (the one I bought at just over $12), quaker state and some brand I had never heard of.
I will hang my head in shame until I get the delco on. I will only be able to drive the car for another month (if I'm lucky) and then it will sit for the winter
I will probably change the oil next spring so it will get a delco (or better) then.
wow-I really felt the need to defend myself hey?
Old Oct 1, 2007 | 06:00 PM
DefenderC5's Avatar
DefenderC5
Several years ago, as an experiment, I cut open a Fram filter for my truck and the filter element was not unlike CARDBOARD. Don't know if they have updated their "filtering technology" but I have not bought one since.
Old Oct 1, 2007 | 06:12 PM
Vega$Vette's Avatar
Vega$Vette
Originally Posted by LIGHTMAN
Mobil 1
To oil filter question
