Caliper painting.
Old Oct 3, 2007 | 01:07 PM
Zozzie's Avatar
Zozzie
Default Caliper painting.
Do you fellows who have painted your calipers remove them or paint them in place? If you paint them in place do you just do the bits that are visible from the outside?
The caliper mounts - did you do them the same color or just black?
While the stainless steel pad covers (between pad and caliper) look great, their $90 price tag at the mail order places is outragous. Has anyone got an alternative?
Old Oct 3, 2007 | 01:17 PM
jserio's Avatar
jserio
O.C.
I think it would be best to powder coat the calipers. It is much tougher then paint. And Yes you remove the calipers to paint them unless your willing to have a half assed job done on your car. I went black on the brakets with white calipers.
Old Oct 3, 2007 | 01:42 PM
peebee_c5's Avatar
peebee_c5
I'm interested in removing mine -- still a bit concerned about removing the brake lines from the calipers though -- any suggestions to avoid air leaking into the lines?
Old Oct 3, 2007 | 01:52 PM
I had mine removed when I painted them, but that was only because I was having other work done at the same time. Many here paint the calipers on the car. I painted mine both front and back and no reason you can't do that while they are on the car. Just takes a little more taping off so the paint doesn't get everywhere.
I painted my caliper brackets black and the calipers red.
Old Oct 3, 2007 | 01:54 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
If you open the brake line at the caliper you must bleed the lines
after you do the install. Do a search on this as this 'DIY' has been
posted here before.
Old Oct 3, 2007 | 02:03 PM
jarsdad1's Avatar
jarsdad1
Many people have successfully painted them without removal. Do a search, there is a complete 'how to" on this.
Old Oct 3, 2007 | 02:16 PM
cletus's Avatar
cletus
I painted mine on the car and they look great. But don't use the brush that comes with the kit. Go to an art store and get a good $10 pointed brush for oils. And build up the paint in 2-4 coats. It dries fast, so you can do the whole car in one day if it's on jack stands. It's been a year and a half (8K miles) and they still look great. Everything red on mine.
Old Oct 3, 2007 | 02:25 PM
Corvette Don's Avatar
Corvette Don
Same with me, I left the brake lines on the caliper but removed them from the rotor, painted them red and still looks new 9 months later
Old Oct 3, 2007 | 02:32 PM
TheDEfan's Avatar
TheDEfan
Check this link out. I'm going to remove mine and panit mine off the car this winter.
http://forums.corvetteforum.com/show....php?t=1799588
Old Oct 3, 2007 | 03:15 PM
02MillenniumVette's Avatar
02MillenniumVette
I originally painted mine and I left them mounted and just painted what was visible. I painted the bracket the same color as well. Now I have powdercoated calipers and they look ten times better than when I painted mine. I recommend getting powdercoated calipers.
Old Oct 3, 2007 | 03:19 PM
jrose7004's Avatar
jrose7004
I took mine loose from the brackets but not loose from the brake lines. I painted the brackets black and painted the calipers red. I painted them with a rattle can.
Old Oct 3, 2007 | 03:33 PM
Junkman2008's Avatar
Junkman2008
I painted mine while on the car and they still look great. The secret is in the thickness of the paint. Multiple coats of thiner paint look way better than a few coats of thick glob. TheDEFan gave you a link to my write up and you can see the caliper up close and painted. There's also a shot of my bracket which I painted black. I didn't have anyone at 4:00AM to help me bleed my brakes so I didn't remove the calipers.
Oh, and I only painted what you could see once the caliper was mounted.
Old Oct 3, 2007 | 03:56 PM
rtprice4321's Avatar
rtprice4321
painted mine in place, took my time masking, thats the most important part. I used duplicolor engine primer after good cleaning, then duplicolor caliper paint (red) spray for both. Took my time, several thin coats is better that a thick one. Then when nice a dry carefully scrapped/sanded the "Corvette" letters.
Old Oct 3, 2007 | 06:19 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
I took mine off and painted them with duplicolor caliper spray paint then high temp clear. Cleaned them up first with brake cleaner/simple green/wire wheel. I don't think I'd have wanted to try that part with them still on the car.
I also invested in a set of speed bleeders, which I highly recommend.
I'm sure powder coating is more durable, but it's a bit pricey.
Old Oct 3, 2007 | 06:37 PM
DGW's Avatar
DGW
Take 'em off and do 'em right, yes you will have to bleed it when you are done. Skip the stainless and paint the back of the pads while you are at it.
Old Oct 3, 2007 | 07:01 PM
AlisonC5's Avatar
AlisonC5
^^^^ Looks really good!!!! Nice work
Old Oct 3, 2007 | 07:13 PM
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
painted mine in place as well...bout to do it again this saturday to go red with black lettering...once you take off the caliper like you are changing the brake pads you can move it and paint the entire thing. You don't have to take off the brake line. Go to my photos and you can see the caliper...pm me if you have any questions...
To Caliper painting.
Old Oct 3, 2007 | 10:54 PM
vetteboy777's Avatar
vetteboy777
Here is a link I found while searching on the web.
http://www.iammoon.com/c5tech/caliper_painting.htm
Old Oct 4, 2007 | 12:23 AM
96CEC4's Avatar
96CEC4
CI 4-8-9 Veteran
St. Jude Donor '07-'08
Nice find.
Old Oct 4, 2007 | 02:45 AM
kikker_1999's Avatar
kikker_1999
Like most I painted mine on the car... lots of DIY's on this.. I also painted the caliper and bracket the same RED... as for the SS on the brakes... when I did my rotor/brake install the pads I bought, Pro Stop Ceramic HAD SS on the front ones.. I get lots of complements on them....
Good Luck
