Mine does this too, pretty badly at high speed. It has been so bad on mine that I have considered installing external hood pins to keep it in place - cause it's damn scary sometimes cruising down the highway with the hood lifting off...
I was told by somebody that it's common the Z06's cause they allow too much air under the hood with the cut-outs up front and it creates a pressure zone under the front of the car.
I can't beleive this isn't a more common concern...
well, this guy is saying his does it too, and its not a z16 but a yellow 02 z
This was taken by me while the car went by at 158 mph... Looks like way to much flex.
Your front end is lifting. It looks like you may have lowered your car and now have a negative rake. At those speeds, with proper rake, you should be getting significant downforce on your car and it should be squatting down with air pushing down on the nose and hood. These cars are sensitive to rake and the rear, at the jacking points, should be higher than the front. FWIW.
Rake is the first thing to check, a ZO6 should not have the light front end issue of the cars of 20 years ago.
Those CF hoods are really floppy. I went with a buddy of mine to pick up one (Z16) in south GA, on the ride back I looked in my mirror and saw a huge gap on the left side of his, it had just popped loose going down the hwy, still latched. Very odd.
Also I'm suprised GM didn't use revalved hood struts with the lighter hood. It's got so much less load on them when the hood is up, when you go to close it you feel like you're going to bend the hood in half.
The hood on my 01 flops around a good bit at speed at track events (140+) so I imagine the CF one does it even more.
I think you are right on the goofy side vent chromy looking things, they do absolutely nothing but reduce air flow out of the engine bay.
just my $.02
Originally Posted by 2TONE82
Houston...I think you have a problem...maybe it's just me but I don't think that's suppose to happen. Can you imagine the force on the hinges? I'd check and recheck the hood/hinges and how things line up. The air should flow over the hood, not under...and excess air in the engine compartment should flow out the side vents...maybe those goofy silver things on the side vets are blocking the air flow from exiting; or is that a reflection? 158 MPH, impressive but this car was engineered to do in the 170's. I'm sure M/T, Road and Track would've shown us all a picture like this had their test drive resulted like this.
I just recently had my z up to 157 and it didn't do this, but I have a vararam blocking off the front vents so I don't get as much air flow under the hood, and my seals are 2 inches short on each side in the back to allow some airflow through them.
Reason #46356 not to buy an '04 Z06 with the sticker package.
Ryan.............so you want a set of stickers for your car and we'll throw in a hood seal too............??????????????????????? This passive agressive behavior of yours towards Z16s really needs some work.
Blue is nice, but everyone has their color preference. I chose red this time.
You chose red THIS TIME!! But are you longing for a Z16? This may be a case of color envy...........maybe you can slap your forehead like they do in that commercial for V8 juice and go:
WOW! I could have had a Z16! It's okay to admit your mistakes on here .............no one here will hate you for it.
Yea Ryan...we are all here for you buddy!! Everyone on this forum knows that deep in your little heart you actually despise a red car and that you really wanted a Z16...you lusted for a Z16...but your mommy or your wife told you "NO...Ryan...you buy a red Corvette just like everyone else has and shut-up"!! Don't hate them, they just had your best interest at heart...they did not want you to stick out in a crowd by driving a Z16. It will be OK....let it all out!!
