[Z06] Z16 hood, do they all do this
Old Oct 3, 2007 | 03:11 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Z16 hood, do they all do this
This was taken by me while the car went by at 158 mph... Looks like way to much flex.
Old Oct 3, 2007 | 03:23 PM
CH.CRAFT's Avatar
CH.CRAFT
It Looks Like The Whole Hood Is Raising Up On The Hinges.
Old Oct 3, 2007 | 03:52 PM
bmg's Avatar
bmg
That looks like a good reason to add a hood seal.
Old Oct 3, 2007 | 04:06 PM
apriliacati's Avatar
apriliacati
How does the hood fit when the car is not moving?
Has it ever been in accident?
Old Oct 3, 2007 | 04:18 PM
Z16_CE's Avatar
Z16_CE
more importantly, why are you not in your car?
Let someone else take the pictures.
Old Oct 3, 2007 | 04:31 PM
miami993c297's Avatar
miami993c297
You need a vented hood to solve this issue...
christian
Old Oct 3, 2007 | 05:01 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Looks like it is packing a lot of air under the front.......vented hood?
Old Oct 3, 2007 | 06:05 PM
garage-ghost's Avatar
garage-ghost
christian
Or remove the rear seal to vent some of that air.
Old Oct 3, 2007 | 06:16 PM
Ryan L's Avatar
Ryan L
Reason #46356 not to buy an '04 Z06 with the sticker package.
Old Oct 3, 2007 | 07:01 PM
l2vette's Avatar
l2vette
You are so full of yourself.
Old Oct 3, 2007 | 07:04 PM
Wicked_Z06's Avatar
Wicked_Z06
Looks like allot of front end lift. Vent the hood, or remove the rear seal like others have said if this is going to be a common thing.
Old Oct 3, 2007 | 07:08 PM
Ryan L's Avatar
Ryan L
What do you mean? That pic does not look safe at all.
Old Oct 3, 2007 | 09:45 PM
Novat_99's Avatar
Novat_99
For someone who dislikes the Z16 so much...you sure do post alot in the Z16 threads...
Old Oct 3, 2007 | 11:15 PM
2TONE82's Avatar
2TONE82
Houston...I think you have a problem...maybe it's just me but I don't think that's suppose to happen. Can you imagine the force on the hinges? I'd check and recheck the hood/hinges and how things line up. The air should flow over the hood, not under...and excess air in the engine compartment should flow out the side vents...maybe those goofy silver things on the side vets are blocking the air flow from exiting; or is that a reflection? 158 MPH, impressive but this car was engineered to do in the 170's. I'm sure M/T, Road and Track would've shown us all a picture like this had their test drive resulted like this.
Old Oct 4, 2007 | 12:27 AM
Z06 Dude's Avatar
Z06 Dude
We are all sure hoping that you don't buy a Z16...after all we have a image to maintain!!
Old Oct 4, 2007 | 12:33 AM
Bill Dearborn's Avatar
Bill Dearborn
I wouldn't be surprised if all Z06s didn't do that at high speeds. The Z16 with the CF hood which is very flexible is probably a little more sensitive to air rushing in through the front screens, over the radiator shroud and hitting the bottom of the hood before exiting from the side vents. This creates a lot of underhood pressure which is combined with the overhood low pressure zone to force the hood up.
Bill
Old Oct 4, 2007 | 12:46 AM
Jeffvette's Avatar
Jeffvette
Nope, never been hit.
Here is a shot of it at the starting line.
To Z16 hood, do they all do this
Old Oct 4, 2007 | 12:47 AM
Jeffvette's Avatar
Jeffvette
Not my car.
jbauch357's Avatar
jbauch357
Mine does this too, pretty badly at high speed. It has been so bad on mine that I have considered installing external hood pins to keep it in place - cause it's damn scary sometimes cruising down the highway with the hood lifting off...
I was told by somebody that it's common the Z06's cause they allow too much air under the hood with the cut-outs up front and it creates a pressure zone under the front of the car.
I can't beleive this isn't a more common concern...
Old Oct 4, 2007 | 02:14 AM
mark896's Avatar
mark896
Isn't that hood carbon fiber? Aren't Z16's the only Z's with carbon fiber hoods?
