Trunk lid liner keeps falling off....does yours?
Old Oct 8, 2007 | 09:05 PM
HOOBS's Avatar
HOOBS
Default Trunk lid liner keeps falling off....does yours?
My trunk lid cover on the inside keeps falling off...the velcro tape is very good but it still falls off...anyone have a quick tip on a quick fix?
Old Oct 8, 2007 | 09:07 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Mine did too. I found some better velcro with a more reliable backing.
Old Oct 8, 2007 | 09:12 PM
OneFastC5's Avatar
OneFastC5
Cruise-In IX Veteran
St. Jude Donor '09
did you clean the lid with alcohol wipes?mine keeps falling also
Old Oct 8, 2007 | 09:27 PM
RTUMARK's Avatar
RTUMARK
mine was constantly falling off, finally went to Lowe's and but some hi tech, hi strength 3M double stick foam tape. All is well so far, has not come off this summer. The stuff ain't cheap and you don't get a lot of it, but enough to attach the liner.
-mark
Old Oct 8, 2007 | 09:46 PM
LTCHAPPA's Avatar
LTCHAPPA
Do you mean the aftermarket liner with the C5 logo? I pulled off those sponge like attachments on the left and right sides of the liner,got some of that 3M double sided tape with the red backing one inch wide.Cut out some small strips of wood about 4 inches x1x three quarter inchs thick.Applied the 3M tape to both sides of the wood strips,Applied the strips to the back side of the liner and the liner back onto the lid. I also did this to the area just below the lid latch.After doing this ,no more liner falling down. Hope this helps. LT
Old Oct 8, 2007 | 10:43 PM
DeeGee's Avatar
DeeGee
I had the same problem. the weight of the liner was just too much for any velcro or 3M tape I used
I ended up using 4 of the push pins I got from Autozone.
I drilled a hole of the correct diameter in the cross braces. Not too hard so it comes through the trunk lid. Popped the pins in and its been rock solid ever since.
Old Oct 8, 2007 | 11:23 PM
fastvetZ06's Avatar
fastvetZ06
I had the same problem as well. My fix was to remove the two large velcro strips from the trunk panel and used 3M mounting tape directly from the panel to my trunk lid. I left the rest of the foam pieces but reinstalled them with 3M tape as well. I went all summer and it's still stuck like concrete.
Old Oct 9, 2007 | 09:14 AM
HOOBS's Avatar
HOOBS
I like this idear! Thanks.
Old Oct 9, 2007 | 09:39 AM
Z0SLIK's Avatar
Z0SLIK
I have a friend that drilled holes!!
Old Oct 9, 2007 | 04:32 PM
spider94r's Avatar
spider94r
The fix that finally worked for me was to throw the piece of junk in the trash. Some aftermarket products just aren't thought out very well and aren't tested in the real world.
Old Oct 9, 2007 | 08:25 PM
Hatchet's Avatar
Hatchet
Good to know...was actually thinking about ponying up the $ for one.
Old Oct 10, 2007 | 12:55 AM
az57chevy's Avatar
az57chevy
Mine has held up to the AZ heat. I placed a piece of styrofaom under each side where I didn't see enough support and used heavy duty Velcro strips on these pieces.
To Trunk lid liner keeps falling off....does yours?
