I have a question
Old Oct 10, 2007 | 03:09 PM
jorgito's Avatar
jorgito
Default I have a question
what is the normal temperature on the c-5. i was driving my car yesterday and the temperature was 240 F and the two fans were constant fast. I have never had this problem before can you help me on my question. thanks a bunch waiting for your response
Old Oct 10, 2007 | 03:27 PM
TexasMadMan's Avatar
TexasMadMan
I have an answer.
That is too high on the temp. This time of the year in CA, it probably should not be above 210-215 in traffic. Maybe even closer to 200.
Old Oct 10, 2007 | 03:30 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
The highest mine will go is 220... the fans should be on after 210...
When was your last coolant change?
Old Oct 10, 2007 | 04:25 PM
C5'S LS1's Avatar
C5'S LS1
If you get a custome tune, You can have the fans set to come on at a cooler temp.
One draw back. More dirt kicked up into the engine compartment as the fans come on more often.
Old Oct 10, 2007 | 04:29 PM
Oldvetter's Avatar
Oldvetter
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
To I have a question
