oil change
Old Oct 11, 2007 | 04:40 PM
Maites's Avatar
Maites
Default oil change
Its about that time for an oil change as my readout is at 9%. Obviously puttting in Mobil 1, but not sure which # to go with. My vette has 41k on it and I know the numbers on oils have something to do with mileage. So what do I get? 10w30? ect... thanks
Old Oct 11, 2007 | 04:49 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Stick with the 5w-30
Old Oct 11, 2007 | 04:53 PM
rws.1's Avatar
rws.1
the numbers have nothing to do with mileage.
A synthetic motor oil meeting GM4718M is required.
5W30 is the preferred viscosity or weight.
10W30 can be substituted if the lowest temperature your car will experience between oil changes is above freezing.
with 02blackbeauty19 stick with
5W30. there is no reason to go to 10W30
Old Oct 11, 2007 | 05:31 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
screw mobile sucks one.
Royal Purple!
Old Oct 11, 2007 | 07:30 PM
Maites's Avatar
Maites
i have heard mixed reviews about royal purple.... any input? and 10w 30 it is..thanks guys
Old Oct 11, 2007 | 07:48 PM
02MillenniumVette's Avatar
02MillenniumVette
I use 10W-30 in mine.
Old Oct 11, 2007 | 07:57 PM
RonJ's Avatar
RonJ
10W-30 Mobil1 here too!
The piston's don't slap as loud with the 10W-30 ... <G>
RonJ ...
Old Oct 11, 2007 | 11:45 PM
jrose7004's Avatar
jrose7004
5w30 in mine!
Old Oct 12, 2007 | 12:07 AM
emquad46's Avatar
emquad46
Stay with the factory recommendation. 5W30. make sure who ever does it knows that it takes more than 6 quarts.. I think 6.5.
Old Oct 12, 2007 | 01:29 AM
max'svette's Avatar
max'svette
St. Jude Donor '11
6.5 quarts...
Also anyone using 0 weight oil??
And yay another oil thread.!!!
Old Oct 12, 2007 | 01:47 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default What??????
I agree with blackbeauty, after all isn't it spelled out on the oil filler cap? Sure you can use Royal Purple in it too if that "floats yer boat"! Just stop trying to out guess The House of Bowling Green
Old Oct 12, 2007 | 03:22 AM
Kamil D.'s Avatar
Kamil D.
how obut the oil filter??? which one is the best?
Old Oct 12, 2007 | 04:28 AM
Kamil D.'s Avatar
Kamil D.
Old Oct 12, 2007 | 04:31 AM
5W30 would be fine in the car.
Old Oct 12, 2007 | 04:37 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Old Oct 12, 2007 | 04:38 AM
Kamil D.'s Avatar
Kamil D.
Old Oct 12, 2007 | 05:48 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by max'svette
6.5 quarts...
Why, yes. Yes I do. Amsoil Series 2000 0W-30.
To oil change
Old Oct 12, 2007 | 07:04 AM
Kamil D.'s Avatar
Kamil D.
any thing??
Old Oct 12, 2007 | 07:21 AM
Tom/99's Avatar
Tom/99
I've ben using 10W-30 in mine, since the first oil change at 2,000 miles.
Old Oct 12, 2007 | 09:46 AM
Dave68's Avatar
Dave68
I spoke to a Mobile 1 technical guy, a short while ago and he told me that essentially, 10W-30 in synthetic oils is obsolete. It provides no benefit over 5W-30 and the 10W-30 takes longer to circulate through the engine at startup temps - even at 70 degrees F.
This particular guy lives in Texas and was using 0W-40 Mobil 1 in his vehicle. For most of us C5 people, 5W-30 is the best choice when using Mobil 1.
