Seafoam use
Old Oct 15, 2007 | 10:25 AM
egypt123's Avatar
egypt123
I picked some up for the first time at Advanced Auto this weekend, so you may find some there if you have a store close by. I only put it in my gas tank because I'm not sure I'm comfortable doing the engine method yet.
Old Oct 15, 2007 | 08:44 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
Originally Posted by hayman
Is it called "Seafoam"? Cause I've looked and can't find it.
I buy mine at pep boys or autozone
Old Oct 18, 2007 | 01:32 PM
ZZ4Vetteguy's Avatar
ZZ4Vetteguy
St. Jude Donor '08-'09
If you just run it through your tank, do you still have to do an oil change like you do with the other way?...I just changed the oil last week.
Old Oct 18, 2007 | 09:17 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
No.
Old Oct 19, 2007 | 11:21 AM
uracowman's Avatar
uracowman
no but it does not clean up the carbon on your valves and combustion chamber nearly as well as using the conventional method.
