What makes a Z51
Old Oct 11, 2007 | 10:19 PM
jdreg's Avatar
jdreg
Default What makes a Z51
Does anyone know what comes with the Z51 in an 04
What parts or systems are upgraded over the base supension
thanks
Old Oct 11, 2007 | 10:22 PM
rayncris's Avatar
rayncris
hi, great question. answer is found by going to 'search'. type in 'Z51' and you will find a very detailed set of information.
Happy searchin
Old Oct 11, 2007 | 10:36 PM
jdreg's Avatar
jdreg
Happy searchin
Tried that before I posted, always do. Could not find anything that really defined the diff. Are you aware of any thread
thanks
Old Oct 11, 2007 | 10:54 PM
04BlueGoose's Avatar
04BlueGoose
This is some of what I remember.
Heavier springs.
Heavier sway bars.
Stiffer shocks.
Power Steering fluid cooler.
If you are thinking of trying to create a Z51 package from an F1 you would do better to get the Z06 stuff(shocks and sway bars).
Not sure in the spring are worth all the bother to change out - some say yes others will say no.
The P/S cooler is an easy change and Gene Culley has a good price on it.
Old Oct 12, 2007 | 09:51 AM
Dave68's Avatar
Dave68
Car & Driver found that a C5 with Z51 and non-runflats handles as well as a C5 Z06. This tells me that the slight differences in component sizes between the Z51 suspension and that of the Z06 are not significant, especially for daily drivers/occasional track use.
Old Oct 12, 2007 | 10:17 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
on an A4 on upgrade to 3.15 gears
Old Oct 12, 2007 | 10:53 AM
Cjunkie's Avatar
Cjunkie
Uh-Huh.....sure
Old Oct 12, 2007 | 10:59 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
The Z51 option was upgraded in 2000 with larger sways.
Swaybar sizes
23mm, front; 19.1mm, rear ----- Base
25.4mm, front; 21.7mm, rear --- Z51 97-99
28.6mm, front; 23.6mm, rear --- Z51 00-04
30.0mm, front; 23.6mm, rear --- Z06
Springs rates
Base-------440/577
FE3 -Z51---525/634
FE4- Z06---525/714
Old Oct 12, 2007 | 01:29 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Heavier springs.
Heavier sway bars.
Stiffer shocks.
I believe they also had the drilled/slotted brakes.
Old Oct 12, 2007 | 01:36 PM
LT1SPUD's Avatar
LT1SPUD
negative on the drilled/slotted brakes.......
Old Oct 12, 2007 | 03:02 PM
MUKAK's Avatar
MUKAK
dont forget the extra $ Gm charges for "Z51"
IMO Z51 is a waste of money......
Old Oct 12, 2007 | 03:09 PM
Dave68's Avatar
Dave68
I believe the "extra money" was about $350. Car & Driver called the Z51 suspension option the "best C5 bang-for-the-buck option, bar none".
I agree; it was just a tiny fraction of the $52K I paid for my car.
Old Oct 12, 2007 | 03:17 PM
zTrek's Avatar
zTrek
To each his own...if you are looking for tauter handling, it's actually money well spent...IMHO. It's the perfect solution for those wanting handling that approaches that of the Z06 but prefer a coupe/vert over the FRC.
Old Oct 12, 2007 | 03:50 PM
rayncris's Avatar
rayncris
right.
If you are going to change it out for aftermarket, that's the only time it might be considered a waste to anyone looking for a tighter suspension.
Curious, why do you think it's a waste?
Old Oct 12, 2007 | 08:26 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
To each his own. The Z-51 C5 package at $350 (went up to $395 early in the 2002 model run) was probably the best bargain on the option sheet.
Old Oct 13, 2007 | 12:21 AM
EaglesNest's Avatar
EaglesNest
While we are on the Z51 subject which are the best replacement shocks?
Old Oct 13, 2007 | 12:48 AM
6pac's Avatar
6pac
I ran around the house yelling "I got z51" the day I bought my car and I kept asking the owner if it had z51 and he said he didn't know. I was a noob then so I didn't know to look on the rpo card
To What makes a Z51
Old Oct 13, 2007 | 12:53 AM
Dave68's Avatar
Dave68
Bilstein Sports are always an excellent choice.
Old Oct 13, 2007 | 12:57 AM
trickflow's Avatar
trickflow
With no build sheet available, how would one know if they have a Z51
Old Oct 13, 2007 | 12:58 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
My 2003 coupe came with the base suspension. I changed the shocks to Bilstein sports and the sways to Z06. I lowered and had a 4 wheel alignment and have been very happy with the results.
