Weird tire sensor reading help!!
Old Oct 12, 2007 | 08:59 AM
OIF2XVET's Avatar
OIF2XVET
Default Weird tire sensor reading help!!
I have a question it was very cold this morning and as I pulled out of the driveway both of the rear tire sensors starting going off DIC reading low tire pressure. I looked and the pressure was around 26PSI. after I carefully drove about 5 miles to work. I looked again and they warmed up to about 32PSI and stopped DIC reading of low pressure. Is this normal or should I put a little air in each? Again it was cold so not sure if that played a part or not.
Old Oct 12, 2007 | 09:03 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Normal for this to occur as the weather changes.
Put air in the tires - WHEN THEY ARE CLOD - 30 lbs.
Old Oct 12, 2007 | 09:36 AM
jrose7004's Avatar
jrose7004
Pretty normal.
Old Oct 12, 2007 | 10:31 AM
rws.1's Avatar
rws.1
Yup.. mine do it every fall... it reminds me to top up the tire air pressure as ambient air temperature drops.
Old Oct 12, 2007 | 11:17 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
also just to let you know the psi in your tires will decrease 1 psi for even 10 degree drop in the outside temp from what I have observed
Old Oct 12, 2007 | 11:20 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Oct 12, 2007 | 11:21 AM
Oldvetter's Avatar
Oldvetter
A lot of people, me included, run about 28 psi in rear tires.
To Weird tire sensor reading help!!
