[Z06] why??
Old Oct 16, 2007 | 11:31 AM
vms4evr's Avatar
vms4evr
Originally Posted by BWATSONZ06
sometimes when I hit the seat memory button it turns my ac on.Its like it has a mind of its own
That's not the same problem the other guys are having. Yours is possessed Mine is too...
If I remember right the memory settings are not just seat position and mirrors. I thought it also included memory settings for the radio stations and the AC settings.
Old Oct 16, 2007 | 01:49 PM
Daytona 78's Avatar
Daytona 78
I thought i was alone with this problem. BTW....My wifes Cadillac does the same intermittent thing.
Old Oct 16, 2007 | 04:54 PM
Bracati's Avatar
Bracati
hot from GM:
THE DRIVER RECOGNITION PROCESS ON YOUR CAR IS RELATED TO THE REMOTE FOB, NOT THE KEY. IT SHOULD RESET TO DRIVER 1 POSITION WHEN REMOTE 1 IS USED TO UNLOCK THE DOORS. THIS SHOULD BE CONSISTENT, IF IT IS NOT, A PROGRAMMING CHANGE “MAY” FIX THE PROBLEM.
Old Oct 16, 2007 | 06:35 PM
u4ick's Avatar
u4ick
Yes this is true...........what ever was set when you turned it off will be the same when you get back in.
You don't have to lock then unlock all you have to do is hit the unlock on the key fob.........
Old Oct 16, 2007 | 06:58 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
Originally Posted by Bracati
hot from GM:
This may be a factor ... I use either set of keys, but I'm always pushing the memory set button for # 1 when infact I just checked and Im carring set #2. dah!
Old Oct 16, 2007 | 07:57 PM
Bracati's Avatar
Bracati
I didn't know about the climate control memory too.
Old Oct 16, 2007 | 09:49 PM
Hooker's Avatar
Hooker
Alas, if such were only true. Most of the time my seat returns correctly - sometimes not. BUT .... my passenger side mirror sometimes moves off my setting ---
Old Oct 17, 2007 | 02:23 PM
HamsHall's Avatar
HamsHall
i love this forum, and don't even have my Z yet you guys are crazy i don't even vist the lotus forum anymore.
Old Oct 19, 2007 | 07:39 PM
Bracati's Avatar
Bracati
It works!
When I push the unlock botton and slide the key into place and so does the seat and other programmed features. Mistory solved
Old Oct 19, 2007 | 09:15 PM
zee sting's Avatar
zee sting
Default For those who don't have time
I just happen to have the book here -
Go to page 2-56:
Any changes that are made to the audio system and climate controls while driving will be automatically stored when the ignition key is turned off. (This answers the one that does not know why his air is sometimes on or off)
When first entering your vehicle, AFTER PRESSING THE UNLOCK BUTTON ON YOUR REMOTE KEYLESS ENTRY TRANSMITTER or a MEMORY button, a recall of your settings will occur when the door is closed and the ignition key is in the ignition switch. (This answers all the other questions as to why it works sometimes and other times not.)
Hopefully this addresses and ends the concern for all.
Old Oct 21, 2007 | 05:47 PM
zulatr's Avatar
zulatr
Go to page 2-56:
In my car, it's still a matter of how the key goes into the ingnition. Yes it knows what settings by what key fob you use, yes it stores more that seat positions, but I thought the question was why doesn't it work every time you get in the car.
As noted above, every thing keys on the door being closed and the key in the ignition.
How does it know the key is in there?
And, it's not because the key is there, as sometimes it doesn't work.
Old Oct 22, 2007 | 02:53 PM
JCENZ06's Avatar
JCENZ06
my seat memory settings just change randomly and the next time i get in the car i have to reset it to where i want it
Old Oct 22, 2007 | 03:15 PM
  #33
Bracati's Avatar
Bracati
JC - that's a bummer
Old Oct 22, 2007 | 07:17 PM
  #34
trentbgood's Avatar
trentbgood
Could it possibly have to do with residual skin oil on the key actuator?
Old Oct 24, 2007 | 03:41 PM
  #35
SFCA1968's Avatar
SFCA1968
I think my key is possessed
Old Oct 24, 2007 | 04:38 PM
  #36
u4ick's Avatar
u4ick
It could be the female key..........that one is usually very uncooperative....
