View Poll Results: How Problem Prone is Your C5?
No Problems in the last year.
56.25%
A Few Problems in the last year.
39.58%
Constant Problems in the last year.
4.17%
Voters: 240. You may not vote on this poll
A Poll: C5 Problems in a Year
Old Oct 15, 2007 | 03:43 PM
cletus's Avatar
cletus
Default A Poll: C5 Problems in a Year
I reccomended the Forum to a friend interested in buying a C5. Because a lot of posted threads involve problems, he thinks C5's are problem prone. I disagree, but thought we should take a poll.
How many have had:
• No problems in the last year?
• A few problems?
• Constant problems?
(Note: Please try and make this C5 specific and not general auto such as: flat tire issues, chipped windshield, hit a deer, etc.
Thanks!
(BTW, after I fixed the steering lock problem I've been problem free for 16 months, 10K miles)
Old Oct 15, 2007 | 03:49 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Have a 2004 daily driver with 54,000 miles. Front turn signal light went out, headlight lamp gear needs to be replaced, and i am having some minor turbo issues. With those kinda miles it's just basically normal issues that would occur anyways.
Old Oct 15, 2007 | 03:50 PM
02MillenniumVette's Avatar
02MillenniumVette
Since I bought the car in '03, only problems Ive had were the column lock, headlight gears, replaced the ABS computer, and the gas gauge needle. Within the last year it was only the headlight gears.
OIF2XVET's Avatar
OIF2XVET
No problems but I upgrade seats and etc.
Old Oct 15, 2007 | 04:06 PM
INGER67's Avatar
INGER67
St Jude Donor '15
2000 Convertible
48,000 miles
I've owned it for two and a half years and had only minor problems(oxygen sensor, tire sensor) until this summer. Had to have the headlight motor replaced and the seat track something or other replaced. Those two items were over $1000.00.
God bless GMPP.
Inger67
Old Oct 15, 2007 | 04:09 PM
sorbet70's Avatar
sorbet70
2002 a4 zero problems........ knock wood
Old Oct 15, 2007 | 04:22 PM
TheDEfan's Avatar
TheDEfan
98 need a new LH fuel sender/pump. The gage is doing funny things and the pump is singing.
Old Oct 15, 2007 | 04:29 PM
OfficeGuy's Avatar
OfficeGuy
...kind of a loaded question. What do you really consider a problem? I wouldn't say that my car is problem free but most things that get fixed or replaced are typical wear and tear items. I've owned a lot of cars and while a C5 is not Civic or Corolla, it is as reliable as anything else. Your friend needs to compare a C5 to other sports cars. If you view the C5 that way you will see that it is the "Civic" of real sports cars. C5 upkeep and maintenance is pretty reasonable as well.
Old Oct 15, 2007 | 04:34 PM
cletus's Avatar
cletus
Good answer!
Old Oct 15, 2007 | 04:54 PM
diyguy's Avatar
diyguy
2000 COUPE MN6 ** OWNED TWO YEARS **
R&R Water pump -- bird chirp - warranty
R&R Pulleys and tensioners- bird chirp- warranty
R&R Harmonic Balancer - bird chirp -warranty- fixed problem - finally.
Bird chirp now back again - new gatorback...some but not complete fix.
Hazard Flasher R&R (no turn signals) - no warranty
Headlight gear R&R Left side - Rodneys gear fix
Fuel Gage inaccuricies - not resolved
Outside Air Temp sensor R&R
Finally got nailed by column lock - fixed w/ COH CLB
That's all for the past two years.
Old Oct 15, 2007 | 04:58 PM
Vega$Vette's Avatar
Vega$Vette
Wanted more power... H/C Headers etc.
Wanted more power.... Supercharger:
No more problems
Old Oct 15, 2007 | 05:01 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Absolutely no problems (including column lock, faulty ops, electrical gremlins, grinding tranny, leaking differential etc etc) here in the past 6 years. Knock on the wood
And I am bone stock too
Old Oct 15, 2007 | 05:05 PM
02MillenniumVette
Mine is bone stock too.
max'svette's Avatar
max'svette
St. Jude Donor '11
2002 Coupe
EBCM module...
Cracked wheels...
Warped Rotors
25k miles on car 6000 miles driven this year so far
Old Oct 15, 2007 | 05:06 PM
LEANDRO's Avatar
LEANDRO
No problems... Well if you count hitting a deer at about 55-60mph, well than one
Old Oct 15, 2007 | 05:11 PM
Mr. Azrael's Avatar
Mr. Azrael
2003 Z06, now 37,000 miles.
-Car would not get up to operating temperature. Needed new thermostat, old one stuck wide open. Went to replace the thermostat myself and noticed a belt off. Which was:
-Crank pulley walked forward and sprayed oil out of the crank snout and chewed the serp. belt a bit. New Belts, new crank bolt.
-Clutch would not disengage (33K). Prognosis: Chevy dealer installed clutch wrong at 24,000 miles, did not torque flywheel bolts nor use loc-tite. Flywheel bolt came loose and gutted everything under the bellhousing and ventilated the bell housing.
-Electrical gremilins. Service Active Handling/ABS has gone off twice, and now the car will be driving and the coolant temperature sensor will drop to 0 on both the guage and the DIC digital (sensor?) and the car will go into open loop rich fuel mode. Car will correct itself within ~10-20 seconds and then start to overheat. Car has a new battery in it, replaced at 30k. Need to check into the temperature drop further...
Old Oct 15, 2007 | 05:16 PM
RedSoxFan's Avatar
RedSoxFan
I've had mine since April. Just discovered a few months ago that the driver's door doesn't lock with the FOB or interior power switch. No biggie, it's on my winter list of things to do while the vert is sitting all by her lonesome in the garage (I'll do the relay repair). I have also had the ABS/Traction Control/Active Handling warning on my DIC. This happened only once about 5 - 6 weeks ago, if it happens again I'll be sending my EBCM to ABS Fixer. I've taken the preventive measures of installing a CLB, running a bottle of techron through the tank, flushed the clutch fluid using Ranger's method,and replaced the AC Delco battery. The car had 15K on it when I bought it and now has 17.3K. I love this car and this forum rocks.
To A Poll: C5 Problems in a Year
Old Oct 15, 2007 | 05:19 PM
steve8's Avatar
steve8
Same problem here, only about 25-30 mph.
Old Oct 15, 2007 | 05:29 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I've had my 01 coupe since Dec 04, zero problems.
Old Oct 15, 2007 | 06:44 PM
lensvet's Avatar
lensvet
St. Jude Donor '05-'07-'08
EBCM Module
Only 28000 miles, seems to early for a major problem.
