Amp
Old Oct 17, 2007 | 12:49 AM
Melodie's Avatar
Melodie
ok, I"ll check it out. thanks. Is this the back of a coupe? Wouldn't you get better air flow with the back of a coupe?
Old Oct 18, 2007 | 10:28 AM
z28flash's Avatar
z28flash
My amp is mounted exactly like in the pictures by RainJ....at the time I was not thinking of behind the seat, but in the rear area it gets plenty of ventilation. I'll take a pic of the carpet later today and post it so the cut out section can be seen.
Old Oct 18, 2007 | 11:01 AM
C6NRED's Avatar
C6NRED
Between the tailights is going to be your best bet.........
Old Oct 18, 2007 | 12:20 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The rear wall mount in my experience has proven to be the most secure way to mount an amp especially when using bolts and lock washers/nuts. It is also somthing that can be easily done whereas most other mounting locations require removal of carpet and somtimes seats to install an anchorboard.
Old Oct 18, 2007 | 01:45 PM
Melodie's Avatar
Melodie
Is your car a coupe or a vert?
