Amp
Old Oct 16, 2007 | 11:33 AM
Melodie's Avatar
Melodie
Default Amp
My amp is placed behind the passenger side. It continually gets hot and cuts itself off. Any suggestions of a better place to put it?
Old Oct 16, 2007 | 11:42 AM
Vette-kid's Avatar
Vette-kid
All of these Audio questions popping up in C5 Gen lately You may find it helpful to look in jthe Audio/Electronics section under General Corvette. There is a lot of info over there and a lot threads w/ pictures about were to place an amp.
As I advised someone else, you will need to be a little more specific. What amp are you using? Whats it running? A smaller amp may work for you back there. I have two behind the seats with no issues, but they are pretty small in size. Beyond that you will need to make an amp rack or something similiar to hide it in the back. Theres really no other good way to keep it concealed with out a creative solution with an amp rack or something. There are a lot of good examples in the audio section, using a partion/amp rack etc.
Good luck
Old Oct 16, 2007 | 11:46 AM
Melodie's Avatar
Melodie
thanks, but I don't want it hidden, it actually needs more ventillation.
Old Oct 16, 2007 | 11:59 AM
Vette-kid's Avatar
Vette-kid
The point I was trying to make was that I dont think you have to give up one for the other. If you dont mind your amp sitting out in plain view than the solution is simple. Just mount it to the floor in the cargo area and be done with it. But if you want it out of sight from sticky fingers, then some have come up with a rack of sorts that hides the amp and still has plenty of ventilation room to kee it cool. Some have even added in fans to help with this function on some REALLY high powered systems. But then as I said, a smaller amp may be in order for you. Im am running a 600w rms mono behing the driver seat and a JL300/2 behind the pass seat with no troubles.
No way would I put an amp out in plain view
Old Oct 16, 2007 | 12:06 PM
BAND1T's Avatar
BAND1T
Couldn't figure out what type of C5 you have... Coupe, FRC or Vert.
I have a coupe and have it along the back wall, plenty of ventilation and with the screen no on can see it.
TJ
Old Oct 16, 2007 | 12:09 PM
kris6868's Avatar
kris6868
If it continually get hot and cuts off id sell it off and get another one. Preferably a mono-d amp or and a amp with a built in fan. Im not saying you dont have good quality stuff but maybe your setup requires a stronger amp to push what you have
Old Oct 16, 2007 | 02:31 PM
Melodie's Avatar
Melodie
It's a convertible.
Old Oct 16, 2007 | 05:34 PM
chris308's Avatar
chris308
I have an Alpine V-12 Expert 5ch amp sitting behind my passenger seat and have no issues with it cutting out. Mines a vert as well.
Old Oct 16, 2007 | 06:14 PM
z28flash's Avatar
z28flash
Mine is mounted directly to the rear wall, centered....at night the blue power light can be seen, but you have to almost lean into the car to see the amp....plenty of ventilation, but you will have to redo your wiring. Seems the small amps work well behind the seats, but as I tend to place other things there at times, I like it in the back. Basically my subwoofer is almost directly in front of the amp...I had my rear carpet cut to go around the subwoofer and placed a protective grill on it....otherwise the subwoofer is fighting to push out air which is bounced back by the carpet (I have a Lloyd's carpet, and I have a coupe)....but for a convertible, I'm not sure, there are more space limitations.
Old Oct 16, 2007 | 06:25 PM
Kale's Avatar
Kale
What kind of amp?
Old Oct 16, 2007 | 07:43 PM
Scooterscott's Avatar
Scooterscott
I have the same setup w/o a hole in the carpet with a stealth Infinity 10". Do you have a pic? I might want to take thay approach.
Old Oct 16, 2007 | 08:27 PM
Melodie's Avatar
Melodie
It's a MtX Thunder 152. I was also noticing that the above amp is installed upright. Mine was installed laying flat down on the carpet. Would that matter?
Old Oct 16, 2007 | 08:29 PM
oaks99's Avatar
oaks99
mine is right behind the waterfall , no problems
oak
Old Oct 16, 2007 | 08:35 PM
Melodie's Avatar
Melodie
is it standing up like the pic below or laying flat down?
Old Oct 16, 2007 | 08:39 PM
Melodie's Avatar
Melodie
mine is way to the back of the trunk. Back where the compartments begin.
Old Oct 16, 2007 | 08:47 PM
Vette-kid's Avatar
Vette-kid
I think Im a little confused on where you have it then. Are you saying its on the floor? So its actually under the seat rather than behind it? If it is under the seat, there isnt much room at all under there for any airflow. Placing it on the wall behind the seat would be an improvement as far as airflow.
heres mine:
Old Oct 16, 2007 | 08:58 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Behind the seat is a good place for your amps. Rear wall is an excellent spot if you're using a sub but for multi channel applications just increases the amount of wire you have to run.
Vette kid: I'd highly suggest mounting your JL amp with the cooling fins on top. This is the way the JL amps were designed to cool.
To Amp
Old Oct 16, 2007 | 09:49 PM
Vette-kid's Avatar
Vette-kid
Well, now that you mention it...that makes perfect sence. Dont know why I didnt think of it. Thanks!
Old Oct 17, 2007 | 12:27 AM
Melodie's Avatar
Melodie
it's not under the seat but way far back, basically in the trunk. And if I have stuff in the trunk it restricts the flow of air. And if the top is down it REALLY restricts its flow of air. But, I like where you have yours, right behind the seat or where Oaks 99 has his as well behind the waterfall might get better air flow as well. And, THANKS for the pics, they really help!
Old Oct 17, 2007 | 12:43 AM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Do go read the C5 Audio section.
There are some nice tips on mounting your power amp and running your cable.
Will save you lots of time and headaches
Rain
