Line Lock
Old Oct 17, 2007 | 12:40 PM
deathstrike's Avatar
deathstrike
Default Line Lock
Is anybody using on their C5 and if you are where can I get the complete for it?
Old Oct 17, 2007 | 01:13 PM
hotwheels57's Avatar
hotwheels57
The product that seems to get the most positive comments is from forum supporting vendor CARTEK. From past posts, it comes complete with pre-bent lines and everything you'll need.
You can find their ad on the main menu page, in the column to the left.
Some other members have used HURST or other after market brands with success, the primary negative complaint being having to bend the lines. Do a search in C5 Tech using keywords "line lock" or similar and you should find some past discussions with images of installations.
Old Oct 17, 2007 | 01:36 PM
nickolbag's Avatar
nickolbag
Cartek line lock here. Good kit.
Old Oct 17, 2007 | 01:38 PM
VetteHunting's Avatar
VetteHunting
+1 Cartek
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Easy to make your own and if you use the Hurst solenoid and get your own fittings/bend your own lines, you'll be in it for under half of what the Cartek kit costs.
Old Oct 17, 2007 | 01:50 PM
deathstrike
I'm new this so I will probably buy the kit.
Old Oct 17, 2007 | 03:16 PM
deathstrike
where do you get the fittings and lines at?
Old Oct 17, 2007 | 03:29 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
I got the adapters for the solenoid (7/16x24 to 1/8 NPT) from Napa, and the M12x1.5 and 7/16x24 1/4" line fittings from a place called Fed Hill (google it). Needed two of everything, plus 1/4" brake line. Yes, these are all the adapters needed, and there's no stacking or adapters save for on the solenoid itself due to there being no 1/8 NPT adapter for a 1/4" brake line.
If you go to your local parts store and get a straight piece of 1/4" line that's about 60" long for about $8-10, you'll get two of the fittings needed (the 7/16x24 fittings) and all the line you'll need.
I'll be posting a complete write-up with pics and part numbers and pricing for what I did within the next couple of days now that I have my car buttoned back up.
Old Oct 17, 2007 | 03:32 PM
hotwheels57
SUMMIT RACING sells the HURST line lock product, but it doesn't come with fittings/brake lines. They made it easy with offering those separately...then you'll need patience and a quality tubing bender.
Go to the SUMMIT RACING website and use keywords "HURST line lock" and you'll find the solenoid, lines, fittings/adapters.
I was thinking that use of the oem fog light switch might be used as the line lock switch...
Old Oct 17, 2007 | 03:54 PM
Julian@Cartek's Avatar
Julian@Cartek
Our Cartek line lock is a prebent kit that bolts right in. If your interested just shoot me a pm or call.
Julian
(908) 317-4496
To Line Lock
