C5 Seat Problems
Old Oct 21, 2007 | 01:47 PM
amcioffi's Avatar
amcioffi
3rd Gear
Default C5 Seat Problems
I've got a 1998 C5 and have been having issues with the driver's seat. When I come to a normal stop (no speed) the seat slides forward about half an inch. It will slide back when accelerating and so on. It will slide back and forth if I move it by hand. I recently found a white delrin bushing under the seat. Does anyone have any idea how I can fix this. Your help is appreciated.........
Tony C
Old Oct 21, 2007 | 03:56 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Tony C
The Search function is your friend. But here you go...
http://www.lieblweb.com/TechLinks/Co.../C5SeatFix.htm
Old Oct 21, 2007 | 04:11 PM
Somewhat common problem with C5 seats. I've got a few Word files that cover various methods of fixing the problem. PM me your e-mail address and I'll forward them to you.
Old Oct 22, 2007 | 06:15 PM
amcioffi's Avatar
amcioffi
3rd Gear
Thanks,
my email address is:
amcioffi@snet.net
Old Oct 22, 2007 | 07:37 PM
vetter79's Avatar
vetter79
Default Re- Seat Fix
This might help U when of if you try to fix your seats. It's not a complicated fix but does take time and care. I found that if you just follow the next two paragraphs when you follow the instructions in the following link it'll make your job a hell of a lot easier
1) There are 2 -13mm hex head screws between the rear seat foam & the rail, holding 2 flat angle plates (these are holding a round cross rod).
2) Remove these and both rails will drop down allowing access to the torx screws (Just use a standard 3/8 drive w/ a standard size 13 mm socket
Then follow the directions from the following link.
Take your time!!
Old Oct 22, 2007 | 08:42 PM
waterzap's Avatar
waterzap
Anyone know if the C6 seats also have the same problem?
Old Oct 22, 2007 | 09:42 PM
robert123's Avatar
robert123
Oh no! Its the dreaded rocking seat syndrome!!! Most c5s will eventually get it. I repaired mine about 6 months ago. Many threads on this topic.
Old Oct 22, 2007 | 11:54 PM
Groucho's Avatar
Groucho
Default Well....
I stuffed a piece of wood in back of mine...
Old Oct 23, 2007 | 12:09 AM
WetteVette's Avatar
WetteVette
If they do, then General Motors is the most stupid, ignorant, auto manufacturer in the world!
In fact, they just might be anyway! With the exception of the Corvette, GM hasn't made a decent looking car in a long, long time!
To C5 Seat Problems
