Cai ???
Old Oct 22, 2007 | 11:26 PM
yaknow's Avatar
yaknow
Default Cai ???
Looking at various induction systems ie vararam, blackwing, stinger/venom, etc.. my question, if you install one of these systems without adding a power duct aren't you just restricting the air flow before it gets to the manifold?
Old Oct 23, 2007 | 12:19 AM
DefenderC5's Avatar
DefenderC5
"Powerduct" is pretty much just for looks. There is turbulence when the air hits the TB and the inside the manifold anyway.
Old Oct 23, 2007 | 02:23 AM
WetteVette's Avatar
WetteVette
In my opinion, unless you're really going to add some serious mods to your engine, i.e. headers, heads, or cam, adding a CAI system is a waste of money.
I'm sure there will be those that think I'm full of it, but hey, it's just my opinion.
That said, recently, members were discussing HP ratings on the dyno. From a post a few months ago about CAI: "the Vararam is not a dyno toy. Take it to the track. You will see a difference."
Old Oct 23, 2007 | 06:01 AM
That's pretty much the same story I have heard.
Old Oct 23, 2007 | 07:42 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
A filter system which draws cooler outiside air (vararam, Honker, hurricane, etc) *will* improve performance.
One that is still sucking under hood air will most likely not.
And that's what I think, anyway.
Old Oct 23, 2007 | 08:55 AM
ZO6TrailblazerSS's Avatar
ZO6TrailblazerSS
A CAI can only be compl. benefited from if it is accompanied by a tune, other than that, its a bolt on of a few HP.
Old Oct 23, 2007 | 11:06 AM
ALVETTE00's Avatar
ALVETTE00
The stock intake is sooooo restrictive...there were a total of four 1 inch holes allowing air into the system.
More air equal more power...colder air equal MORE power. Getting a CAI will permit both.
Here's what air does...
For every 10 degrees you cool the air, you gain 1% engine power.
For every 1 pound of boost, you gain 7% engine power. (in the case of Superchargers & Turbos)
Hope this helps...
Old Oct 23, 2007 | 06:49 PM
yaknow's Avatar
yaknow
thanks
To Cai ???
