Help!!! Dic Has No Comm.
Old Oct 23, 2007 | 08:20 AM
97CO's Avatar
97CO
Navigator
Default Help!!! Dic Has No Comm.
I Am Unable To Run Through The Codes On My 97.
Any Help Is Appreciated
Thanks, Chase
Old Oct 23, 2007 | 08:49 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
We'll need to understand the issue more fully to assist.
Are you following these instructions to gain access to the codes:
Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button (BE SURE THAT YOUR DOORS ARE CLOSED). Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occured in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
Does the DIC accept this process?
Old Oct 23, 2007 | 10:27 AM
97CO's Avatar
97CO
Navigator
It Will Let Me Try To Run The Codes But They All Pop Up
Ecm- No Comm.
Rdcm-no Comm.
Every One Of Them Does This
I Was Having Trouble With The Pass Door Window Would Not Work. I Check The Wires In The Door Jam All Ok So I Changed The Pass Door Modual And The Window Started Working But Only From The Pass Side Will Not Work From Drivers Side.
Thanks Chase
Old Oct 23, 2007 | 10:36 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I had to read that heading twice
Old Oct 23, 2007 | 10:45 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
If I understand the issue - this started after changing the passenger door module - correct?
Prior to that activity there was not a problem - correct?
Presumming the above is correct - I would first disconnect the 'new' passanger door module.
Now try the DIC.
If it works, the problem is isolated to the module (and or connection).
Let us know the results.
C5'S LS1's Avatar
C5'S LS1
Your bad
Old Oct 23, 2007 | 11:02 AM
C5starman's Avatar
C5starman
CI 7-8 Veteran
It may not apply in your case, but check out the electrical sticky in the Tech section. There is a wire in the door to body connection that can cause many problems if bare.
My seats stopped holding memory settings. It was driving me nuts. I did the simple fix posted by Bill Curlee and it took care of my problem.
It is worth a look.
Old Oct 23, 2007 | 11:45 AM
97CO's Avatar
97CO
Navigator
Before I Changed The Door Modual All Guages Were Crazy
Temp At 260
Oil At 0
Fuel At 0
The Pass Window Would Not Work
And The Dic Would Run Codes Every Once In A While
After Door Mod Was Changed All Guages Appear Fine
But The Dic Has No Comm.
Pass Door Works But Not From Drivers Side Only Pass Side Controls
Thanks, Chase
Old Oct 23, 2007 | 11:55 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I hope this isn't it but you need to check this:
Take out the battery and look under it. Did the battery leak on the cables and computer underneath?
I hope not
If it did I recommend you consider trading the car.
If it did not, replace the battery and reconnect. Cross your fingers, it may have been a temporary glitch. Very likely there was nothing ever wrong with the window control module.
Good Luck
Old Oct 23, 2007 | 12:14 PM
timemender's Avatar
timemender
Did you check the wiring to both doors?
Check the individual pin connectors and check the grounds.
Start at the doors, battery & under the battery, then common grounds under the hood, followed by the connections on the modules in the passenger foot well.
See the sticky at the top of the C5 tech section.
Keep testing to see if the codes will run.
Old Oct 23, 2007 | 01:13 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
Temp At 260
Oil At 0
Fuel At 0
Thanks, Chase
Damn
Ok - like posted above - remove the battery - check very CLOSELY under the tray and verify if there is battery residue. Also check the grounds (passenger and drivers side).
BTW - how old is the battery???????
If there is none - leave the battery disconnected for 15 minutes or so.
Reconnect and see if you can now see codes.
If you cannot - I strongly recommend that you post this in the Tech section - seeking more options.
Old Oct 23, 2007 | 02:18 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Temp At 260
Oil At 0
Fuel At 0
Thanks, Chase
I had the same issue (gage readings were haywire and NO COMM) and it was the wire harnesses from the body to the pass. door.
Just like Bill Curlee recommended, I shook the accordian hose and the window started working again. I then removed teh accordian hose and found that the tubing over the bare wire had mover (shrunk) and created a short ... a little electrical tape and she's good to go.
I hope that this solves your issues as well.
To Help!!! Dic Has No Comm.
