MPH light questions?
Old Oct 25, 2007 | 10:07 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default MPH light questions?
I've noticed that while driving, the blue "MPH" light in the speedo will occasionally fade (but not go out copmletely) then light back up completely. Is this a strange kind of feature or is there an electrical problem?
Old Oct 25, 2007 | 10:09 PM
MorpheusGPR's Avatar
MorpheusGPR
Mine has not done that, I was curious if the RPM was suppose to light up too?
Old Oct 26, 2007 | 12:27 AM
jayindy's Avatar
jayindy
...since you mentioned...at lunch today I was waiting in the car while my wife went into an office supply store and I noticed some momentary fading of the heater LED display and of the radio display (faded in/out in sequence)...I didn't think much about it, I looked at my volt meter while the engine was running and it seemed to hold steady...and I also looked at the digital read...I think it was around 13.8 or so volts...I know from past cars when the alternator is ready to retire, the headlights will dim / fade in and out of brightness....I'll assume a minor quirky thing.
Old Oct 26, 2007 | 12:55 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Same problem.
Old Oct 26, 2007 | 03:46 AM
RedRckC5's Avatar
RedRckC5
ditto
Old Oct 26, 2007 | 05:02 AM
moserbe's Avatar
moserbe
I have noticed that the intensity changes with the amount of sunlight. Take that into account and see if yours is the same.
Old Oct 26, 2007 | 07:13 AM
Bob CTS's Avatar
Bob CTS
Yep same thing, shine a flashlight in the light sensor above the buttons to the right of the steering wheel (fuel, trip etc) you will see it change in intensity.
Old Oct 26, 2007 | 07:14 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I've never experienced that or that I have noticed!
I'll check it out this weekend when I take it out for a run or two!
Thanks,Matt
Old Oct 26, 2007 | 07:39 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Take a look at it on a sunny day and when you go under an underpass. It will dim in the sun and brighten under the bridge.
Normal
Regards
The Pup
Old Oct 26, 2007 | 07:42 AM
Storm Cloud's Avatar
Storm Cloud
I notice mine are dimmed at idle and on start up. I think what's happening is your alternator is only supplying a certain amount of juice with the belts turning slow. As soon as I start to move it lights up more, so I assume the belts are turning faster and supplying more power to the alternator. I also notice when entering the freeway that my radio gets louder slightly and I assume it's the same situation as the MPH light.
Let's hope this isn't a sign for us that our alternator is not working correctly!
Old Oct 26, 2007 | 09:44 AM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
That is not an alternator problem -it's Speed Controlled Volume (might not the correct name, but I don't want to go dig out my owners manual). You set the volume on your radio, but as your speed increases SCV adjusts the volume automatically.
z06Bigbird's Avatar
z06Bigbird
Some C5s have instrument panel lighting integrated with turn signals. Check blinker fluid.
Old Oct 26, 2007 | 10:28 AM
Oldvetter's Avatar
Oldvetter
And don't forget to check the muffler bearings and rotate the air in the tires !
Old Oct 26, 2007 | 10:32 AM
02MillenniumVette's Avatar
02MillenniumVette
If you will notice, its a lot brighter at night than it is during the day when the sun is out. Same thing if it gets overcast or your in the shade, etc.
Old Oct 26, 2007 | 10:57 AM
TimeCr0ss's Avatar
TimeCr0ss
I noticed my MPH light would do the same. However, I never noticed it would adjust to lighting conditions. I'll check that out today.
Old Oct 26, 2007 | 11:04 AM
c5chines's Avatar
c5chines
There is a light sensor on the panel with the dic switches that auto dims and brightens the mph display.Looks like a screw hole. Chuck.
To MPH light questions?
