Cruise control does not work. Help
Old Oct 26, 2007 | 01:42 AM
WAG 3's Avatar
WAG 3
6th Gear
Default Cruise control does not work. Help
I have 99 coupe. Fuse is ok. any suggestions or ideas. Car is bone stock.
Old Oct 26, 2007 | 02:45 AM
soggysailor's Avatar
soggysailor
I have an occasional issue with mine. It has to do with the brake sensor. I need to have it adjusted. The tolerance is too tight and it makes the car/cruise control think the brakes are on. I've found if I put my foot under the brake pedal and just lift up it sets the switch enough to get the cruise control working. I should fix this correctly but its so EZ to do this. I don't know if this will help.
