Pulley part number
Old Oct 26, 2007 | 11:26 AM
bkel33's Avatar
bkel33
Default Pulley part number
Does anyone know the non-gm part number (dayco,goodyear,etc) for the Idler pulley for the a/c belt? There are two pulleys for this belt, one tensioner and one idler. The only idler pulley I have found at parts stores is for the main drive belt. I have checked carquest, craigen/ checker and autozone.
My car is a 99' Coupe a4. SHould be the same for all c5s. Thanks!
Brett
Old Oct 26, 2007 | 07:27 PM
bkel33's Avatar
bkel33
the gm part number is 12557434, but I can't find a cross.
Old Oct 26, 2007 | 08:17 PM
Bob CTS's Avatar
Bob CTS
I got this looking up in my parts book:
Tensioner 12557334 w/ pulley GM part number
Pulley 12560345 GM part number
Both these pull up at GMpartsdirect.com
The pulley is the same, if the tensioner is good it uses the same pulley as the idler.
Hope this helps
Old Nov 1, 2007 | 11:51 AM
bkel33's Avatar
bkel33
Hope this helps
That pulley is the idler for the main belt. The one i'm looking for is not listed ANYWHERE but GM. Doesn't even show in GMparts direct.
Got it fixed. In case somebody is needing to replace this:
Checker/ Craigen carries pulley bearings
get a bearing that matches and you can press it into the pulley if you have a press. (The bearing is much too tight to use a clamp or a hammer)
No more sqeeulley squeek. Thanks rspreng02_Z06 for looking that up!
-Brett
To Pulley part number
